-   -   Front cooler install (http://forums.pelicanparts.com/porsche-911-technical-forum/183407-front-cooler-install.html)
84toy 09-19-2004 04:16 PM
I am in the process of installing a front cooler and I am nearly done. My only disappointment is the cooler is in front of the air inlet for the A/C condenser fan inlet which I know won't help the A/C.
While apart, I tossed the old horns since one of my horns was bad anyway and replaced them with a set of Cadillac horns. ($5.00 at Pick and Pull) Turned out to be a nice improvement in the "noise" category.
http://www.sayegh.org/Paul/porschepics/cooloer2.jpg.JPG
Bottom Brace (rubber lined)
http://www.sayegh.org/Paul/porschepics/bracket.jpg.JPG
http://www.sayegh.org/Paul/porschepics/bracket2.jpg.JPG
Top Bracket (rubber mounted)
http://www.sayegh.org/Paul/porschepi...racket.jpg.JPG
Cadillac Horns
http://www.sayegh.org/Paul/porschepics/horns.jpg.JPG
Moses 09-19-2004 04:28 PM
Very nice! How much room do you have behind the cooler for air flow?
84toy 09-19-2004 04:32 PM
Not a whole bunch. About 1" average. I was quite worried about that part but it seems that these big coolers have enough cooling capacity that it is not a big issue. I bought a BW valance and removed about 1/2 the rolled lip of the opening for the cooler. This allowed me to move the cooler forward a little more.
Moses 09-19-2004 04:37 PM
Mine only has about an inch but seems to work well.
911pcars 09-19-2004 04:38 PM
Nice job on mounting the cooler. It even looks like you could add a "crash" bar that spans between the two support brackets in case someone decides to intrude in this space. Are they aluminum like the upper mounts? Might even be good mounting points for an add-on splitter under the bumper.
Sherwood
Yellowbird RS 09-19-2004 06:25 PM
Nice setup!
good job
Bill Verburg 09-19-2004 06:58 PM
More cooling than you'll ever need
warpspd 09-19-2004 07:57 PM
Where did you get the cooler at?
84toy 09-19-2004 08:29 PM
I got the Setrab cooler from Chuck Moreland at Elephant Racing
Chuck Moreland 09-19-2004 08:52 PM
Paul, very clean install. I like the bottom bracket you fabbed. The rubber is a nice touch.
