-   -   Testing Injectors? (http://forums.pelicanparts.com/porsche-911-technical-forum/183459-testing-injectors.html)
WydRyd 09-19-2004 08:41 PM
Testing Injectors?
Hi,
What's the best way to check/test if an injector (or injectors) are clamping down under heavy load?
Mark McClure 09-19-2004 09:10 PM
Merv,
You can use a NOID light whi you can get at many auto parts places. It gives you a light and confirms the electrical circuit. Flashing is good solid or out is bad. However this does not test under load............unless you can get a friend to hang on to the back of the car while you drive. Or use a dyno!
Cheers
Mark.
