Mooligan's Avatar
84 930 Rear Axle Torque Specs
Can anyone confirm the rear axle torque specs for an 84 930?
I replaced them recently, and followed Wayne's 101 saying that if you have 6 M8 bolts to torque to 34ft-lb, compared to having 4 M8 bolts needing 61ft-lb.
I ask because mine actually dropped right out on me on the way home yesterday, had to get a tow
I havent managed to get a set of manuals yet
Old 09-20-2004, 08:27 PM
TurboRuf's Avatar
Mooligan,
There is an addendum to the 101 book with the proper torque specs. I believe your 84 is the same as my 85, which should be 61ft-lb.
85 930 Ruf BTR
Old 09-20-2004, 08:30 PM
Mooligan's Avatar
Thanks for the quick reply, I just came in from working on it, will finish tomorrow.
Looking over the book just not seeing this addendum. So your pretty sure of the 61ft-lb? You have the 6 bolts as well and not 4 M8's?
Maybe you can help decipher this readout from my Mitchel On Demand CD's, this is what it says for rear axle torque specs:
M8-12K 31ft-lb
M10-8G 34ft-lb (this is what I had them at)
M10x55-12K 60ft-lb
What are those numbers after the M10, what is the difference between -8G and x55-12K?
Old 09-20-2004, 08:55 PM
TurboRuf's Avatar
Sorry, the addendum isn't in the book.
Check this link...
Torque for 930 CV joint
85 930 Ruf BTR
Old 09-21-2004, 07:10 AM
Mooligan's Avatar
Ah thanks a lot, guess that confirms it. That was almost a costly error..
Old 09-21-2004, 10:20 AM
