Virginia Rocks!
VaSteve's Avatar
What are these things in the tunnel?
I am installing a fire extinguisher on the tunnel cover (correct term?) Under the front holes, I noticed these bars...what are they? See my finger.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 09-17-2004, 08:46 AM
The clutch and throttle cable tubes! I think thats what your pointing at
Ben
Old 09-17-2004, 08:48 AM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
fuel lines (send & return) also run in those things
A word of warning: Don't try to weld your seat brackets back onto the tunnel, the fuel lines run in tubes just like those right under the welds. (ask me how I know)
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 09-17-2004, 09:42 AM
Oh yes look up towards the front of the tunnel and see if they go into rubber lines then you'll know they are fuel lines. Just be careful
Ben
Old 09-17-2004, 09:45 AM
I would rather be driving
jpnovak's Avatar
the tunnel has guide tubes for the following. 2x heater cables, 2x parking brake cables, 2x fuel lines (supply and return), clutch cable tube, throttle linkage bar, And on early cars, two tubes that supply vapors to the charcoal canister and then back to the intake for "recycling".
Old 09-17-2004, 09:47 AM
the light at the end of the tunnel.......
is a train
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 09-17-2004, 09:48 AM
skinnerd's Avatar
whatever you do.... don't touch them with your finger!!!!!
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 09-17-2004, 09:53 AM
Me like track days
Craig 930 RS's Avatar
....to late, decontamination is in order now......
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-17-2004, 09:57 AM
Virginia Rocks!
VaSteve's Avatar
It was so clean in there before...
Anyone have a guess what that wiring harness is for?
Old 09-20-2004, 07:16 PM
reverse lights ?
76/3.0 tarcabvertible
64 corvette conv.
72 Alfa GTV
79 Jeep Cherokee Chief
Old 09-20-2004, 08:11 PM
