Rodney Nelson's Avatar
The Electrical Gremlins attacked with full force today.
I was driving to dinner tonight and I gave my car a little bit of gas and I heard terrible pinging. I looked out the review mirror and I saw a cloud of smoke, when I let off the gas the pinging stoped and so did the smoke.
I then looked down at the gauges and my O2 light and Battery light were on.
When I came back home the car seemed to be driving fine, however I did not give it even a little bit of gas because I did not want it to ping again. The battery light and O2 light were still on. Then my Tach started reading 5K then nothing, it had a mind of its own.
I got it into the garage and let the car idle for a second it droped down to 900 rpms then it kicked up to about 1500 rpms. I then turned it off and I opened the engine compartment and I could smell and electrical burning smell.
Were should I start looking?
My car is and '82 SC with the O2 sensor disconnected, with no mods mechanically.
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 08-25-2004, 10:14 PM
Slumlord
Porsche_monkey's Avatar
The used Porsche classifieds.
Seriously, maybe a wire harness inspection? Sounds like something melted causing a couple of problems.
Also, measure your alternator output voltage, that will tell you if you have a problem with the indicator light vs a real alternator problem.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-26-2004, 05:13 AM
I don't think it is an alternator problem because I think with the pinging somehow I got a different air fuel mixture. Plus the O2 sensor came on as well.
Would the alternator have an electrical burning smell if it went bad?
Old 08-26-2004, 05:45 AM
Designer King
Paulporsche's Avatar
Do a litle sniffing and try to locate the source of the burn smell.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-26-2004, 05:52 AM
Slumlord
But your o2 is disconnected, so I suspect a harness problem possibly feeding the DME.
Are you sure the pinging is related?
Yes, a toasted alternator can smell, measyure the output voltage first. It's easy and it will tell if there is a problem.
84 Cab - sold!
Old 08-26-2004, 05:53 AM
indigowhale's Avatar
Send a message via Yahoo to indigowhale
Get a voltemeter and measure battery voltage when car is running. If should be no more that around 14.5 (tops). Your spike in the tach may indicate a bad voltage regulator and this is 3 minute test could rule that out.
Also, turn your headlights on and look for a flicker, it is another crude simple way to look for irregular high voltage.
Old 08-26-2004, 05:54 AM
konish's Avatar
what type of ignition box are you running? with the idiot lights, it doesn't seem to make sense that it could be the ignition box, but I'm not looking at a wiring diagram either. All I know is when my Permatune went bad it did all sorts of crazy stuff...
R/
Dustin
Old 08-26-2004, 05:56 AM
Oh, and another thing, the burning smell could be your battery boiling from too much voltage, so don't go setting any sparks off near it. The gas is explosive and has a very distinct odor.
Old 08-26-2004, 05:57 AM
Okay,
Unfortunately, I am at work right now. Thank you for all of your inputs. I will be checking it out tonight.
I am running a stock ignition box.
The reason I think the pinging is releated is because it never did that before and since the O2 light came on I was thinking maybe somehow my mixture was changed?
I should have sniffed around some more. I hope it still smells when I get home.
I am interested in checking the voltage regulator and the alternator. Could you guys please elaborate on how to check the alternator voltage and regulator.
I have my trusty volt meter ready
Old 08-26-2004, 08:38 AM
Slumlord
Negative lead on the battery -ve terminal, +ve lead on the other (red)terminal. Meter on the 'dc volts' scale.
Check voltage with the key out, then with the engine idling. Post the two numbers here.
84 Cab - sold!
Old 08-26-2004, 08:48 AM
I got home today and tried to see if I could find any loose wires or anything evident and I didn't.
I turned the car over and it was running pretty rich even after it warmed up for a while.
I then shut it off and came inside and got my volt meter.
I then measured the voltage as PBH said with the key out and I got 10.45 - 11.01 Volts. Then I went to turn on the car and nothing. It would not even crank. All of my assecories came on with no problem?
Now what????????
If the O2 light is on what does that mean???????
My car has an optima battery that is only 1.5 years old and it seems pretty strong.
I have the factory CDI unit and I am running the Blue coil. Nothing else fancy.
Old 08-27-2004, 07:11 PM
when the tach floats, that generally means that you're running out of voltage to run it. low voltage also makes the electric fuel pump run slower, which causes low fuel pressure. the smell may have been the alternator frying, because it doesn't work now. a new alternator with internal regulator and charge the battery, and everything should be normal again.
206 637 4071
Old 08-27-2004, 07:25 PM
John,
Is there anyway to check the alternator in my cars condition before purchasing a new one.
I did have this one rebuilt for a wable problem about 1.5 years ago.
Old 08-27-2004, 08:01 PM
Okay, It has been three weeks or so and I removed the alternator, housing, and Fan.
I had my alternator rebuilt and a new regulator installed, the shop said it was bad.
I then had my fan and housing powder coated, which looks amazing I might add.
I fired the car up this morning, and the lights are still on bright as ever.
What do I do now?
Old 09-19-2004, 09:29 AM
What is your voltage now with the engine running?
I am assuming that you have an internal voltage regulator and that it was replaced in the rebuild?
...if it is external, you may be in luck. It would be on the left side of the engine bay under some cover. If it is a S.V. Marchall, I have a slightly used one for sale in the Used 911 Parts section of this board. It takes 10 minutes to replace.
If your voltage is normal 13.5 - 14.5, do you have Sylvania Silverstar headlights?
Old 09-19-2004, 04:30 PM
No, it has a brand new voltage regulator, it is internal.
Old 09-19-2004, 07:29 PM
Early_S_Man's Avatar
Porsche Crest
Rodney.
I don't believe the O2 lamp is related to your other problems.
The O2 warning lamp is controlled by a counter mounted behind the instruments which gets its' signal from the speedometer terminal #'A'. Every 30,000 miles ... the mileage the counter turns the warning lamp on ... indicating that the O2 sensor needs to be changed. The mileage counter can be reset with a small screwdriver to push a small recessed switch inside the counter case.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-19-2004, 07:59 PM
KNS KNS is online now
indigowhale,
You asked about the Sylvania Silverstar headlights, any reason? I think that's what I have.
Kurt
Old 09-19-2004, 08:27 PM
Warren,
That is unbelievable, I never heard of that before! I had no idea that there was a counter. I will find it and reset it. But why is my battery light on while the car is running then if that is the case?
Old 09-19-2004, 11:49 PM
Porsche Crest
The alternator warning lamp is a separate issue. Check your system Voltage again.
Warren Hall, Jr.
Old 09-20-2004, 05:37 AM
