A/C fuse/relay ?
I have a 80 911 with no power to the a/c switch, i have power at the fuse and tried swapping relays. Is there any inline fuse or relay not located at the fuse box?
TIA |
There is another relay in the smugglers box.
AFJuvat |
Also check fuse 2 and 3, in some years a jumper was put in to power the condenser fan and other stuff. I just had a problem where the fuse looked good but when removed, it had a grey powder that came off. I replaced the fuse and it worked.
| All times are GMT -8. The time now is 05:23 AM. |
