Flat or Deep fuchs - how tell??
Can someone explain how to tell the difference between flat and deep sixes? Do you have to measure the inside of the rim or can you tell by visual inspection while on the car?
Use the search facility to check out previous threads on this subject - there must be hundreds of them !
Side by side...they are obvious....only in six inch.
They look a bit different...and of course, the deep sixes have a 901 part number on the inside as opposed to the 911 number on the newer ones.
| All times are GMT -8. The time now is 11:59 PM. |
