911mot's Avatar
Rear end 'shimmy'
I'm getting a 'shimmy'/vibration through the seat of my pants as I accelerate hard in 3rd and 4th. Most noticeable accelerating full throttle from 120kph in 4th gear and it fades with speed. I'm thinking possibly a driveshaft or CV joint or is there anything alse I should check first?
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 09-23-2004, 02:05 PM
You do not have permissi
john70t's Avatar
The only other thing I could think of was worn suspension bushings-i.e the tires twist outwards under load and are no longer parallel.
Not sure that that would happen only in those conditions.
Old 09-23-2004, 02:17 PM
911mot's Avatar
john- I'm pretty sure it's there all the time but when you accelerate hard in 1st and 2nd it all over to quick to notice it
My passenger could feel it too. It's like a pulsing that gets faster with roadspeed but only under hard load.
1984 3.2 Carrera
Old 09-23-2004, 02:28 PM
Designer King
Paulporsche's Avatar
Rear tire(s) out of balance?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-23-2004, 02:33 PM
audi2.7t's Avatar
Most probably a bent rim ,possibly a bad tire...
'96 Dodge Viper
'09 Maxima
'05 zx10..(0-100-0 before your turbo even spools!!)
'99 Rottweiler
'08 Cane Corso
Old 09-23-2004, 02:41 PM
911mot's Avatar
paulporsche I think I can eliminate wheel and tyre issues because the fault was noticable before I swapped to the 16s that are on there now.
I will check the balance again though as they are toyo r888 trackday tyres. Maybe they go out of balance easy or maybe I steam cleaned a weight off earlier when I washed it. hmmmm
1984 3.2 Carrera
Old 09-23-2004, 02:42 PM
911mot's Avatar
I should add the tyres have done 300 miles since fitting (by me at work, carefully)
1984 3.2 Carrera
Old 09-23-2004, 02:44 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
I would be concerned about the CV joints/half shafts.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 09-23-2004, 02:45 PM
911mot's Avatar
Yeah I'm pretty sure of it too just wanted confirmation. Is it more cost effective to service the shaft or to buy a replacement?
1984 3.2 Carrera
Old 09-23-2004, 02:52 PM
