Not much for brakes
I just got my cr back from the shop. I had a clutch job and some seals replaced. Now, I have s@#$ for brakes. Is there anything that I can check to bleed? Is there anything in doing a clutch job that involves the brakes or lines? I'm perplexed. TIA
Also, the brakes are hard, not much give.
What car are we talking about here? It could be as simple as the vacuum line for your power brakes got disconnected during the clutch work.
If no power brakes, you could have kinked lines or other issues. Although a soft pedal is usually an indicator that things need bleeding or you have air in the system, not a hard pedal.
'76 911 Carrera 3.0 |
MBruns for President
Maybe grease on the rotor... Could be lots of things
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
its a 3.2 carrera. I think its a vacuum line.
What kind of car are you talking about, year and model?
Me like track days
Above all - take it back to the shop and say, gently......WTF????
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
