Phoenix's Avatar
Early vs. Late 7R cases?
I'm searching for a 7R case to use as a basis for building a 2.7 RS spec motor. Can someone tell me if the following case number is the 2.4 7R case or the later 2.7 7R case? I can never tell the difference.
901.101.102.7R
Many thanks guys!!
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 09-23-2004, 06:39 AM
jluetjen's Avatar
Oliver;
I believe that that number is the casting number. My understanding is that the only difference between an "early" 7R case (from a 2.4 liter motor) and a "late" 7R case (from a 2.7 liter motor) is the dimension of the spigots which is just a machining change. The thing is that once you've machined the spigots of a 2.4 case to fit 2.7 cylinders, the world has lost a 2.4 case forever.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-23-2004, 10:26 AM
Old Member
Oliver
Check the serial number. The 1973.5 2.4T used the 7R case. The serial number should indicate 613XXXX for an early case.
Clifton Brown
https://www.mancalamarketing.com
Old 09-23-2004, 12:35 PM
