Polished Fuchs Care/Upkeep
My polished Fuchs (were done by previous owner) are aluminum, right? Probably not coated with a clear coat???
Can/should I polish with a quality aluminum polish? They're starting to possibly look a tad hazy and would like to clean/shine. Many thanks, Skip
1972 911T 1972 911E "RSR" |
I use Mother's polish-seems to work well for me.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Designer King
Check out a recent thread on the use of Vaseline as a coating on the Fuchs.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Vaseline is only good on black finish! I believe Skip refers to polished...
Ed- Did you use Mothers Aluminum Polish, I believe in the small round container at the parts store? Also, looks like the stinkin' weather man got us again! Thanks, Skip
Ova Day
The 911 owner's manual recommends vaseline but I believe the orginal finish is painted (center) and anodized (rim). The story might be a little different for bare polished aluminum. Vaseline works great on my stock Fuchs. I'm using an ancient jar of Vi-Jon that has a .12 price sticker. I think Vi-Jon has since been bought out by Zymol. P)
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 |
I've used several brands on my polished Fuchs with similar results from each - none has been that much better than the other. My most recent experiment has been Mothers Billet - has worked good but expensive?
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
I've used numerous products, a quick review:
Flitz: Expensive and messy, but good results. Too runny for my likeing. Mothers: Very good, also great for removing fine scratches. Wenol: Also very good, not as abrasive scratch removal. Eagle 1: Similar to Mothers in compound and results Cotton Wadding (sold in can), I believe it is made by Eagle 1: Very easy to use but lacks and compound for scratch removal. Takes a fair amount of polishing to bring them to a shine. Any compound that can remove the oxidation layer will work. I like to use the Mothers or similar compount to remove any stubborn water marks. I actually hit my Fikse's with some cleaner that had acid in them (a no no) and this left a fine etching of water marks, even after immediately rinsing. The Mothers polished them right out. I like to think of using the more abrasive cleaners as a continuation of the finishing process. Each time you use them, your Fuchs get a little better. The vaseline is only recommended to help restore the appearance of the anodization on the original rims. As fare as the painted surfaces, a simple car wax should suffice.
I have tried mothers and others and found them to be less than impressive unless you really rubbed and polished like crazy. I tried Blue Magic Metal polish cream (for chrome ,aluminum,and mag wheels) last winter, really inexpensive and fairly "rub on wipe off " stuff. It has a amonia like smell that you have to get used too, but ease of use was a winner for me.
HTH Timmer sorry about the pic quality ![]()
Sorry,
The pic on the lower right should have been the "before" pic. Tim
Tim 82 SC 90 C2 Yasowatt |
I am with 89911 on the products, except that the Fltz is the best - most agressive and easy to use aluminum polish. It is not cheap but if labor is the expensive part
it is the best!.If it is too runny, buy the tube which is a paste and can be bought from any yacht store. I then apply Starbrite Teflon polish to coat it! For anodized finish try the vaseline - or, try a mild abrasive polish with a wax or coating bulit in !.
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
Skip-You're right about the weather. It is the Mother's in the little can with red label. Either labeled "wheel" or "aluminum" polish-can't remember.
