how do these oil pressures look?
the engine is a 204 horse 3.0 SC with 175000 miles. the cold start oil press is 3.4 at 1100rpm. after a good rip for 15 mins the oil press is 1 at 900rpm, 2.2 at 2000rpm and 3.5 at 2750rpm it is low on oil, will this make much of a difference to the oil pressure?
thanks people Andy
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Sounds pretty good to me. I get a little higher cold oil pressure (just under 4) hot is pretty similar.
Those pressures look good. Porsche says you should have 4bar at 5000rpm with the engine at operating temp.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
sound ok to me.
(I've heard 1bar per 1000rpm is about right)
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
Yeah, the typical coarse standard is one bar per 1,000 hp, and your pressures look just fine.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Thanks blokes
Andy
