Did 73 2.7RS's ever leave the factory with fibreglass bonnets? (ie. trunk lids)
I'm re-classing my rally car and am trying to work out if I can use my steel or f/g bonnet. I'm limited to whatever came from the factory " in the day".
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) Last edited by obrut; 09-29-2004 at 07:57 PM.. |
I believe all that had ducktails had them in fibreglass. It could be specified with a normal lid.
EDIT: Peter Morgan in Original Porsche 911 states "On the M471, glass-reinforced plastic was used for both the bumpers and the rear engine cover, which had an aluminum support frame." Can you even get a non-F/G ducktail? Last edited by klaucke; 09-29-2004 at 05:24 PM.. |
He means the front trunk lid.
He's from Australia
yep, we have boots (in the back) and bonnets (in the front)
although for a 911 engine lid seems to be ok also for the rear now back to the question - were there fibreglass front bits??
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
I am 99.99999% positive a 73 RS has a steel hood. I think for lightweight versions in the 90's they didn't even use F/G, they used aluminum.
Thanks JK - that's what my research points to as well. Pity, my steel bonnet feels like it weighs a ton in comparison to my f/g one.
A FG bonnet/hood will save 15 lbs. over a stock steel one. CF might save more.
The RS used a lighter steel for the hood -- 0.7 mm steel. That would save you something -- but is it worth the cost of fabrication? I doubt too many real RS owners will sell you their bonnets. Anyway, good luck. |
The 73 RSR did have a glass hood. You can argue it is legal because the RSR was homoligated from the RS. Good luck.
Best, Don |
I would rather be driving
The 911R also had fiberglass boots and bonnets. Don't know if it would help your argument. The ST used aluminum. I think the RS was all steel.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Bird. It's the word...
Can I have your glass one?
John Forcier Current: 68L 2.0 Hotrod - build underway |
