-   -   8 way power seat disassembly (http://forums.pelicanparts.com/porsche-911-technical-forum/185135-8-way-power-seat-disassembly.html)
Leland Pate 09-30-2004 05:13 PM
On my last 911 (SC coupe) I had a pair of late model high backs installed. The drivers side bolster was just beginning to show the first signs of wear. In order to keep it from getting any worse I swapped the seat backs. It worked like a champ since they were universal.
It's the same story with the 993 seats.
...at least, that's what I thought.
When I removed the four 15mm bolts that hold the seat back to the bottom, it wouldn't come free. Upon further inspection, I can just barely make out what appears to be a shaft of some sort going into the bottom portion of the seat back. I then started thinking... "hmmm... these are '8 way' seats and I think my old car only had '4 way' seats."
So, I dug through my trusty factory manuals and found a bunch of info on adjusting/replacing the lifters but N O T H I N G pretaining to disassembly of the seat backs.
Does anyone have experience taking these seats apart? Is it more trouble than it's worth?
Ideas?
swbsam 09-30-2004 05:23 PM
good luck,
I just replaced one of the switches and it was major sugery, these eight way seats are nice until you have to work on them.
Leland Pate 09-30-2004 09:13 PM
Well, I'm looking square at a circlip on a shaft that goes "into" the seat back. I'm really kind of scared to remove it without knowing the consequences.
Anyone???
