Fitting Webbers to CIS Heads
I am fitting a set of 40 Webbers and standard early intake manifolds onto a 2.5 motor with 2.7 CIS heads with 32mm ports.
Do I need to "fill" in the CIS notches on the heads and if so what is the best method? Robert |
Oops - Just noticed that I posted on the wrong board. How do i move or delete the post?
Robert |
The easiest way is to call/FAX PMO carbs. They sell a carb/head insulator that is specifically shaped to cover the CIS injector port. They are oblong versions of the std. carb gaskets.
http://www.pmocarb.com/ |
| All times are GMT -8. The time now is 12:34 PM. |
