Jcon's Avatar
What's easiest way to find vacuum leak.
I'm not a fan of spraying carb cleaner into a hot engine bay...what else can I use to look for leaks on my 3.6.
Jeff C
Jeff C
76 912E 2.6L
Old 10-02-2004, 04:42 AM
Water, propane. Carb cleaner is the easiest. IMO
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-02-2004, 05:44 AM
The BEST way is to use a "smoke machine". OTC and Vacutech make one. They are very expensive, around $1000, but I used one and found a vacuum leak on just about everything I own in seconds.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 10-02-2004, 07:32 AM
911mot's Avatar
If it's 'hissing' put a length of pipe to your ear and fish around with the other end near where you suspect it is leaking. You will hear when you've found it.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 10-02-2004, 08:44 AM
I have an electronic beeper vac and exhaust detector. I paid about $150 from Snap-On. I believe OTC sells the same unit. I guess "toolman" would know more about it?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-02-2004, 11:02 AM
Jcon's Avatar
Ronin
Do you like it?
Jeff C
Jeff C
76 912E 2.6L
Old 10-02-2004, 11:19 AM
Originally posted by Jcon
Ronin
Do you like it?
isn't there a spray for detecting an intake leak?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-02-2004, 11:37 AM
Propane bottle with a hose on it. Turn on the gas and move the hose tip around all your fittings. Engine will speed up noticeably when leak is present.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 10-03-2004, 05:34 PM
Ronin
Do you like it?
I've lent it to shops that have spent days trying to find a vac leak.. usually 15min-1hr and it's found with this unit.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-03-2004, 06:00 PM
