84porsche's Avatar
Send a message via Yahoo to 84porsche
Wheel Well Cleaning
Any of you guys clean out your wheel wells? I just attempted to but I know I got a long way to go. Can you guys provide me with some inspiration pictures?
You can see the before and after.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 10-02-2004, 04:07 PM
1973911s's Avatar
Michael
1984 Carrera Targa Sold to fellow Pelican
1973 911S Targa - Sold to fellow Pelican.
Old 10-02-2004, 04:10 PM
84porsche's Avatar
Michael,
What on earth did you use to clean it that well? I spent about two hours with a brush, simple green and goo gone.
2003 VW Jetta GLI
Old 10-02-2004, 04:12 PM
1973911s's Avatar
The pictures look better then in real life.
Some guy came by the house selling this all purpose cleaner. I sprayed it on, let it sit, hit is with a brush and then used a sponge to wipe off. I will see if I still have some, I might have used it all on the last well.
Who has the SOCG graphic?
Michael
Old 10-02-2004, 04:15 PM
84porsche's Avatar
Thanks for the info on the cleaner. I will keep trying, I stained the driveway again so I will need to find something to clean that as well.
SOCG Graphic
2003 VW Jetta GLI
Old 10-02-2004, 04:19 PM
1973911s's Avatar
Just looked didn't have any more, also use hot water.
Michael
Old 10-02-2004, 04:30 PM
Noel's Avatar
I too have this project on my list and after one failed attempted using Simple green with a weak POS powerwasher am curious if anyone else has used any other methods.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 10-03-2004, 06:21 AM
The PO of my Carrera lived in a rural area with oil and stone roads. The entire undercarrage looked like it was paved!
I drove it over to a truck stop with a steam cleaning bay early on a Sunday morning. Brought the speed jack and stands, and popped all wheels off. The combination of steam, pressure and whatever solvent they use melted the gunk away incredibly. Im talking spotless- behind the hoses and lines, brackets, oil cooler etc. Looked new when done.
There was enough road gunk to fill a couple of good size buckets laying under the car. An unbelievable mess. Satisfied after about 4 hours, I washed the car and was on my way. They charged me about $70 and cleaned up the bay after I left. I think that was the best $70 that was spent on the car to date.
Dave
84 Guards Red Coupe
Misc. other fuel consuming toys
Old 10-03-2004, 07:10 AM
zbph10's Avatar
At work I have access to a high pressure steam cleaner, it peeled the crud off with ease. Good luck
HEAT+PRESSURE=CLEAN
Old 10-03-2004, 07:54 AM
MBruns for President
JeremyD's Avatar
I used 3m adhesive remover that I sprayed on and simple green. scrubbed the 3m with a bristle brush. sprayed the simple green on full strength and let it sit.
Everything came off pretty easily after that.
Old 10-03-2004, 07:55 AM
rob justice's Avatar
Spray on cleaner, good pair of waterproofs and a power washer!!!
Couple of hours work, no problemo.
Old 10-03-2004, 09:00 AM
Make Bruins Great Again
Por_sha911's Avatar
Be careful with Simple Green-it attacks AL in a big way. Make sure you get it off asap. Also, be careful with pressure washers-One slip and you could be repainting a fender.
Joe
Old 10-03-2004, 11:24 AM
Zeke's Avatar
Amen to that if you are using 2000# or higher and have a pointy tip on it. Otherwise, not too much danger.
Man, you sure can get soaked doing that and get a face full of dirt from the backspray.
Old 10-03-2004, 12:00 PM
1973911s's Avatar
Zeke,
How is the repairs going this weekend?
Michael
Old 10-03-2004, 12:08 PM
Glasgow 911SC's Avatar
hehe Been there, done that....and walked around all day not knowing i was covered in the cr@p.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 10-03-2004, 12:21 PM
