-   -   Scruffy needs better lights! Please chime in (http://forums.pelicanparts.com/porsche-911-technical-forum/185466-scruffy-needs-better-lights-please-chime.html)
Superman 10-05-2004 04:06 PM
Yep, Tyson is the best.
I am using the direct-replacement H4 units that do not change the appearance of the car. I'm using 11w highs, which make nighttime into daytime, but I'd like to go even brighter. My relays can handle that, but my wiring may not be able to, so I plan to eventually get super-duper lamp sockets and then upgrade to 130W highs.
If these lights are aimed properly, oncoming traffic will have no issues. Until you forget to dim......
jpnovak 10-05-2004 04:10 PM
ARe you getting the Cibie 40 series (tango)? that's what I mounted on my grills. Do you need brackets for them? They are bright enough that you can't see oncoming car lights until you physicaly see the car's lights. No more looking for glare off trees and guard rails. They are perfect! Careful in the twisties. Its easy to blind oncoming cars.
mjshira 10-05-2004 05:15 PM
hey Noah, if those are the ones that Dan sells, then yes. Do you have 100w bulbs in them? Where can I get some brackets?
yeah superman, Tyson is cool dude, it would be a blast to live in LA and get to hang out with all the great p-cars fans out there, plus the backroads there are the BOMB.
david914 10-05-2004 07:26 PM
Yeah Grady, I wouldn't do that for long with the stock setup, but I'm running a pair of 40 amp relays. Only a few milliamps of current going through the dimmer switch. Good thought on the grounds. I'm sure many people don't even think about that end of the equation!
swbsam 10-05-2004 07:38 PM
http://forums.pelicanparts.com/uploa...1097030316.jpg
autoxracer31 10-05-2004 09:32 PM
silverstars all the way. they work wonders. fog light silverstars too.
Speedy1 10-05-2004 09:47 PM
any of you guys have the link for the relays?
mjshira 10-06-2004 03:17 PM
Speedy1 just do a search for Dan Stern and you can get everything you need.
What I am looking for now is some brackets for the horngrills as I want to mount lights there, does anyone know where to find some?
Thanks!
jpnovak 10-06-2004 03:38 PM
James, I made my own set. I can make you a set too. You will have to cut your horn grills to make them fit.
Here is a thread where I made my own.
http://forums.pelicanparts.com/showthread.php?s=&threadid=172392&highlight=grill+ lights
Here is another good link with some info from another board member who can make you a set.
http://forums.pelicanparts.com/showthread.php?s=&threadid=180479&highlight=grill+ lights
I have also seen a flat bracket that mounts to the top bolt of the battery box and does not require the grill to be cut.
http://forums.pelicanparts.com/showthread.php?s=&threadid=84332&highlight=grill+l ights
mjshira 10-06-2004 03:48 PM
thanks Jamie. Trying to do everything I can to get more light on the road when I use highbeam. And its another fun project! I will read these threads and send you a PM. THX
mjshira 10-06-2004 03:55 PM
Jamie I didn't see any pic of a kit that mounts to the battery box?? Do I have to cut the horn grill? Finally, the lamps I am going to run are from Dan and I will have 100w bulbs in them. They may be a little bigger than the stock ones... thoughts?
mjshira 10-06-2004 03:59 PM
swbsam, great pic by the way!
Grady Clay 10-07-2004 08:43 AM
Here is the current thread with a proper relay wiring diagram:
http://forums.pelicanparts.com/porsche-911-technical-forum/185809-911-headlight-101-a.html
Best,
Grady
mjshira 10-07-2004 08:45 AM
thanks Grady. Ronnie sent me a link to that one too. Seems like several folks are dealing with this issue to.
jpnovak 10-07-2004 09:22 AM
James, clean out your PM box. check the sent and saved folders too.
mjshira 10-07-2004 09:27 AM
cleaned out!
jpnovak 10-07-2004 09:35 AM
Still says full. I will try again shortly. Wait... you have (hot)mail.
mjshira 10-07-2004 12:30 PM
OK, now its cleaned out for real!
skipdup 10-07-2004 12:41 PM
But skip the diode for the high & lo beam on at the same time mod.
buttjoint 10-07-2004 02:51 PM
If you replace your H5s with H4s can you use your original trim ring or do you have to paint the ones that come with the H4s Thanks
