Slant83cab's Avatar
Question oil level sender replacement
Hello...a quick question...
When replacing the oil level sender in the rear wheelwell, does the oil have to be drained first or is the sender at the "top" of the oil reservoir so I won't have a major mess
Old 10-04-2004, 06:16 AM
it's on the side, so you need to drain it.
206 637 4071
Old 10-04-2004, 09:13 AM
Slant83cab's Avatar
thanks...will do
1983 slantnose cabrio
2005 Carrera 997
2003 Mercedes E500 sport
2004 Lexus RX330
Old 10-04-2004, 09:38 AM
Also, make sure all that crude from years and years of driving is cleaned off before you remove the old sender from the tank. If that stuff falls in the oil reservior, it could be messy. I spent more time cleaning than replacing when I did mine.
Sean
'77 911S Cab Conversion
Old 10-04-2004, 10:57 AM
