911SC - shifter bushing replacement
Hello to all. 1983 SC - sloppy shifting, bushings were worn so I replaced them all.
I replaced the coupler a few years back and about 3000 miles ago and it's still good. Currently the trans is in neutral. I adjusted everything as per my Bentley manual but now I cannot shift into 5th or reverse. 1st - 4th is good. Adjusted it a few times but no change. I think I might have accidentally rotated the coupler while re-setting the set screw but rather than hunt and peck I thought I would reach out to the much more knowledgeable gents on this forum and ask for help. Thanks in advance for any help - Dennis |
PCA Member since 1988
That's almost certainly what you did. Try rotating the coupler back one spline at a time until 5-R will engage.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thank you Pete - as I face the rear of the vehicle counterclockwise or clockwise ?
Facing the rear of the car: Pull the splined coupling apart and rotate the shift rod clockwise. Try one spline. If you need more, go a little further.
Yes. I have found that as little as one spline can be the difference between not reaching a gate at all and perfect shifting.
'80 SC Targa Avondale, Chicago, IL |
