Rear Camber
I was looking at my rear wheels the other day and noticed that the top of the wheel comes in a bit. Reading through some posts I believe this is the camber? Is there some way to measure if mine is ok? I recently got new tires and the previous tires had even tread so I wasn't worried about alignment. Car goes perfectly straight. I have included a pic that I think shows it pretty well. Using a big T I can see there is about a 2cm different from top to bottom.
85' 911 Coupe
sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob...
Old 10-04-2004, 05:01 PM
jluetjen's Avatar
Visually your tire doesn't look unreasonable. If the wear was fine on your previous set of tires and the car drives straight with no pulling, I'd assume that it is alright. If you really want to know what it is you'll need to measure it with alignment equipment. Once you've done that it's really a question of understanding what you want the rear camber to be. That's a more complex question but if you do a search through this BBS on "alignment", "camber" or "do it yourself alignment" you'll probably learn more then you want to.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-04-2004, 05:43 PM
Zeke's Avatar
Looks like qutie a bit of camber for the street. Check the orientation of your rear torsion tubes that are attached to the spring plates. As you look at the end sticking out, it should be in the center of the outboard bushing bracket. When the factory rubber bushings get tired and worn, the tube moves up in the hole and you get lots of negative camber whether you want it or not.
Old 10-04-2004, 07:40 PM
Jeff Alton's Avatar
The factory spec is 1 degree negative. I run 2 degrees, but my car sees a lot of track time. At 2 degrees you see it in tire wear, the inside edge does certainly wear faster.
Jeff
www.turn3autosport.com
Old 10-04-2004, 09:15 PM
