Compression numbers #
I just did a compression check on my 911 2.7 L -1975 with 50 000 Km since Top End Rebuild. Can anyone tell me what a normal compression reading would be.
Here are my results cyl# - compression (psi) 1 - 157 2 - 158 3 - 148 4 - 158 5 - 150 6 - 140 Thanks, |
There really is no "normal" what you are looking for is no more than a 10% deviation between the cylinders. Was the engine warm with the throttle open? If not retest. If so I would investigate why cylinder 6 is reading low. Maybe just piece of carbon caught in the valve or need a valve adjustment. Check and retest.
| All times are GMT -8. The time now is 02:26 AM. |
