-   -   jacking your car (http://forums.pelicanparts.com/porsche-911-technical-forum/185724-jacking-your-car.html)
Slant83cab 10-05-2004 06:00 AM
jacking your car
a quick question...
where is the best place to jack your car with a scissor jack. The box style door rails have no holes to access the frame holes to use a jack plate. If I use the jack plate inside the box rails, it comes out too far and hits the door rails. any other locations that are strong enough to lift one side of the car at a time?http://forums.pelicanparts.com/uploa...1096981223.jpg
astark 10-05-2004 06:15 AM
Welcome to the board. If you use the search function in the upper right corner and use search terms like "jack, jack points, jack location" you will find a lot of information.
That said, most on this board recommend a floor jack in all but emergency situations. I have used a jack pad (available from our host) and a floor jack to raise a side of the car with no problems. Always be careful to place the jack on locations that can withstand the load (not the floor pan, not oil lines on the pasenger side etc).
Good luck, Nice car (thanks for posting pix)
Alan
As always PLEASE use caution and err on the side of saftey (chock wheels, use high quality jack stands to suppliment the floor jack, make sure you are on levle ground, etc).
Slant83cab 10-05-2004 06:46 AM
Thanks...and yes, the scissor jack is for emergency repairs roadside if needed. Even if I had to change a fat rear tire, I wouldn't even begin to figure where to put it !!! I use the floor jack for in garage service!SmileWavy
Jeff964 10-05-2004 08:21 AM
Are the car's flatnose and boxer sides factory options?
Slant83cab 10-05-2004 08:51 AM
special order in the late 80's models. This was a steel slant conversion by a previous owner on an 83 cabrio. He added flare wheelwells, box skirts, and whaletail, white gauges and brushed aluminum to the lower dash among many other details, repairs,ect., and then as most of us can attest, ran out of money. Alot of fun for a Miami Vice look!
88911coupe 10-05-2004 03:59 PM
I know this is of no help but that's great looking car!
Oldporsche 10-05-2004 04:20 PM
Sometimes is use a pad with a sissor jack or floor jack. It's a piece of 2X4 with a groove cut in it. It will straddle the pinch weld on the bottom of the frame rail boxes.
Good luck,
David Duffield
widebody911 10-05-2004 04:25 PM
Nice car!
Here's how I do it:
http://66.34.72.138/garage/updates/image/2100981.JPG
Trust Me 10-05-2004 05:43 PM
Now that's a scissor jack!!!!! Show-off!~! LOL. plan on doing something like that some day.
vanwyk4257 10-05-2004 05:52 PM
You can jack the car up on the engine sump, just make sure you use a block between the sump and jack pad. I've also jacked the front end of the car up using a 2x8 board on the jack pad that's long enough to support both the A-arms. Make sure you chock the front wheels if you jack the car up by the sump plate (I know it's obvious, but it's worth reminding).
Slant83cab 10-05-2004 05:56 PM
thanks..
911pcars 10-05-2004 09:47 PM
I assume you're asking about "emergency" situations where your car is away from the garage. Block the diagonal wheel, then place the scissors jack under the control arm, front or rear. I wouldn't suggest lifting under the crankcase.
Sherwood
vanwyk4257 10-06-2004 02:38 PM
911pcars, if you look in Wayne's 101 projects book it clearly states that you can jack the back end of the car up by the bottom of the crankcase FWIW.
abisel 10-06-2004 02:54 PM
widebody,
How much for the duck tail sitting against the wall?
911pcars 10-06-2004 05:08 PM
vanwyk4257,
There was a previous thread on this subject not too long ago. I understand that's what Wayne suggests in his 101 book. Others point out Porsche owner manuals suggest otherwise.
You can search the archives for the different points of view.
Sherwood
vanwyk4257 10-06-2004 05:59 PM
Sherwood. I must have missed that thread, thanks for the info!
HarryD 10-06-2004 08:22 PM
Yes you can but do you really want to lift your car by the single most expensive component of your car?
vanwyk4257 10-06-2004 08:26 PM
Harry, point well taken
