Kach22i,
I have a 77 3.0 euro, and in the course of tune up, replaced the rotor cap, and points. The rotor was the revlimiting, and it WORKS..... It's a cheap and easy way to limit rpm's with no electronic or fuel involvement. Shorty after I installed the points, they wore the rub block enough to close, and I experienced the Tach needle bounce and drop and a fuel stravation....when the points would try to work then I got backfires....big time. A simple adjustment and cleaning of the points worked again. With my goal to eliminate those kind of future problems, I replaced the points with Petronix the next time I had the problem... So far no more problems, and power comes on like it should. If by chance i push it to 7,000 the rotor shuts er down....it works great |
I paid 30 mins labor to my mechanic to put in a petronics set about 3 years ago. My '77 911s has run flawlessly ever since.(except for rear wheel bearing problems)
Is there a cheep fix or do you just replace the complete axle assembly which includes boot, CV joints and bearings for $500 each side (parts only)? |
kach,
Here is what all 2.7 rotors are supposed to look like ... if your car has the correct distributor in it: http://www.pelicanparts.com/techarti...just_pic16.jpg The CIS 2.7 distributors all have the same specs as a 2.4T distributor, so I suggest reading the following thread, which has all of the pertinent factory data for your distributor: http://forums.pelicanparts.com/showthread.php?s=&threadid=5432&highlight=distribu tor+lube My suggestion is to forget throwing money at a wrench that actually knows very little about maintaining YOUR car ... get a timing light with inductive pickup and advance readout capability. Pull your distributor with engine at TDC #1, and partially disassemble, clean and check for wear on the bushings, etc. After cleaning and lubing, check the advance curve per the factory documentation. |
| All times are GMT -8. The time now is 04:26 PM. |
