Question Have a couple stripped door hinge bolts!
I went to remove the driver's side door from my '72 this evening. Four of the bolts came loose with a 6mm hex socket, however someone must have tried the same thing once upon a time with an SAE hex socket because the interior of the socket head is stripped out. I thought no big deal I'll just drive a torx socket in and take the bolts out, but a T-40 is too small, and a T-45 is too large. Does anybody know if they make a size between a T-40 and T-45 or am I going to have to drill these out? Also, is there a specialized tool to remove these bolts or is a 6mm hex socket the best way to do this? Thanks!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 10-07-2004, 04:45 PM
Mike69T's Avatar
Drill them!!!!
69T RS clone in the making
Old 10-07-2004, 04:48 PM
Tim K's Avatar
This has happened to me a number of times. All thanks to PO s. I've found the easiest thing to do is to grind any paint off the top and weld on a bolt. The damaged fastener is junk anyway.
Good luck.
Tim K
Old 10-07-2004, 05:02 PM
