-   -   Rust on an SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/185814-rust-sc.html)
onewhippedpuppy 10-05-2004 06:05 PM
Rust on an SC?
I'm talking to a guy with an '80 SC for sale, he claims excellent condition, but it has a couple of spots of surface rust. On a galvanized SC, should this be an instant no from my perspective? Can this happen from simple chips, or is it indicative of poorly repaired accident damage?http://forums.pelicanparts.com/uploa...1097024699.jpg http://forums.pelicanparts.com/uploa...1097024708.jpg
Rot 911 10-05-2004 06:14 PM
I've seen rust on a number of SC's and Carreras. Not sure about the rust there at the fender seam, but the rust at the bottom of the door is probably a result of the drain holes being blocked. I bet that door is rusted from the inside out.
dtw 10-05-2004 06:14 PM
Exposed galvanized metal will not remain clean indefinitely. Eventually the sacrificial zinc layer will oxidize and the steel will finally be naked and exposed to the elements. The shots you show look like neglected chip damage to me, but they are in potentially scary places. The cowl could be rotting at the seal/fender flange, and the door could be rotting from the inside out due to clogged drains. It would be difficult to decide on this car based on the photos shown without a detailed going-over.
Dennis Kalma 10-05-2004 06:18 PM
Be very careful, the worry is often that the rust you can see is often indicative of rust you cannot see,for example, check the torsion tube, the rocker panels (inner rear fender looking forward) and the front bumper mounts on the inner fender.
Personally, unless the price is very good or you have a chance to examine in much greater detail, I would look for a one minus the risk factor of rust
onewhippedpuppy 10-05-2004 06:27 PM
Trade non-withstanding, he's been asking 9k, and it has 150k miles on it. Claims it runs/ drives great, interior looks good in pics. I had enough rust with my T though, I'd prefer to avoid it in the future. Seems high for an '80 SC.
epbrown 10-05-2004 08:14 PM
Actually, that sounds about right to me for the mileage and condition. As someone else pointed out, those look more like untreated rock chip damage than surface rust from deeper issues. Doesn't bode well for how well the car has been cared for, but it's not the nightmare a pre-galvanized car might be.
stealthn 10-05-2004 08:20 PM
Excellent condition and rust , kinda sounds like an oxymoron. Rust is like rats you see one (spot) and you can be guaranteed, there's alot more you can't see.
It depends what you are looking for, a real fixer-upper, stripped down to bare metal and fix, or a good conditioned car you can customize to your taste....
Good luck :D
Aussie 10-06-2004 01:13 AM
Probably just the tip of the iceburg
ScottKelly911 10-06-2004 01:47 AM
SC's and Carrera's are NOT impervious to rust. They are less likely to rust if well taken care of than earlier cars. However, a galvanized car is like a water-RESISTANT watch not like a water-PROOF watch. See the difference. No car including the Stainless steel Delorean is completely safe from the rust bugs. On this particular car, I am with the others that say, what you can see is probably only a token to what you can't see. Walk and don't look back, there's plenty of rust free SC's out there. Just my opinion
Wil Ferch 10-06-2004 05:28 AM
The area you show at the welting....top/rear of fender as it mates to the cowl...is a particulatly sensitive area for rust.
Even cars that show no evidence of rust anywhere else....show the start of rust in this area, as evidenced whenever I walk into my good friend's body shop with the fender removed. The small "ledge" immediately below the fender at this point collects a bit of debris and surprisingly almost all 911's we've seen have rust on this ledge.
--- Wil
Rot 911 10-06-2004 06:32 AM
I disagree with the others telling you to just walk away. All those pictures are telling me is that you need to give the car a good look over for additional rust and ajust the purchase price accordingly.
JBO 10-06-2004 06:39 AM
IMO, anyone who allows a 911 to get like that without even touching up the areas has not taken care of the car at all. Would need to be real cheap for me to consider one like that.
911SCfanatic 10-06-2004 07:14 AM
JBO, good point. Neglect like that means neglect elsewhere.
Jdub 10-06-2004 07:25 AM
I agree with JBO.
When you see the car in person, be especially careful to check the area just in front of the lower corners of the windshield. If you can, get inside the car and peel back the moulding of the windshield at the lowermost corners.
Check for any bubbles along the same area, from fender to fender, across the wipers.
Open the front hood, and note the areas around the bolts to the fenders very carefully. Open the sunroof and make careful inspection with bright flashlight inside the cavity. Check also, using mirror, the underside of the roof.
If he lets you, remove the speaker from the door panel and again use the mirror to have a look at the door bottom.
Check very carefully the rear tailights: above and below. Get under the car if possible remove the left rear tire and shine a light back into the tailight to expose all of the dirt, rocks, and whatnot that lodge above the tailight and cause rusting. Do the same for the front sidelights/turnsignals.
By the way: all of these areas, tailights, door bottoms, etc. should be thoroughly cleaned and waxed/preventative grease (Waxoyl) as a rule. It takes a few weekends, but you will be amazed at the crap you find, esp. around the tailights, and front valance, etc. Don't just wash and wax: do the hard detail work and apply two coats of wax (for example, when the tailight housing is out) to help your car survive The Tin Worm.
John
Hetmann 10-06-2004 07:29 AM
A little rust may just be a great bargaining chip for you. Were you planning on painting the car? If not, pass. But if you were look deeper and adjust accordingly.
My car had some rust issues and I thought I was in for some body work. Turns out that after I had my car media blasted, all my rust spots were surface rust.
Tim K 10-06-2004 10:11 AM
83 SC
Leaking Front windshield seal.
http://forums.pelicanparts.com/uploa...1097082229.jpg
The back window looked similar.
Also leaking battery.
While not pretty, theses were the only rusted areas. It seems that the galvanized body of a neglected car will only stand up so long. When an area is penetrated, it's a slippery slope.
Tim K 10-06-2004 10:13 AM
And yes, anything that you can actually see when the car is fully assembled and covered in paint will usually be much worse.
hkspwrsche 10-06-2004 04:54 PM
I dont what part of canada your car is from but, I've seen cars from canada with only 3years on them and rust started on the fenders and quarters. The only SC I've seen in Viginia with rust (on Left fender) -I commented to the owner that it was unusual and he said "I'm from upstate newyork".
I think the door bothers me the most because it could be an inside out problem.
The nose(fenders and hood) of my car was painted 2 years ago for rock chips but, the rest of the paint is a 10 -12 year old respray and no rust is bubbled or showing through. It's not garaged currently.
I wouldnt write it off but, maybe investigate. How long has that paint been on the car? is it original? Check the normal spots that rust and if no problem ask whoever does the ppi to take the trim panel off the left door.
Harold
Aussie 10-06-2004 10:55 PM
Why buy one with rust, when you can get an SC rust free?
They are dime a dozen!
Its not like its a pre 74 where rust free cars are rare as hens teeth.
competentone 10-07-2004 02:11 AM
"Rust? What rust? That's nothing a little Bondo can't fix!"
:eek:
http://home.earthlink.net/~jaegan23/.../Floorpan3.jpg
http://home.earthlink.net/~jaegan23/.../Floorpan1.jpg
onewhippedpuppy 10-07-2004 04:51 AM
This all brings back memories of my T.......rusty pictures make me all sentimental.:p
Tim K 10-07-2004 06:59 AM
"I dont what part of canada your car is from but, I've seen cars from canada with only 3years on them and rust started on the fenders and quarters....."
This was a Texas car
Tim K
Tommy B 10-07-2004 08:54 AM
i'm gonna throw my two cents in although i'm no expert.
my car had "rust issues" that most of you would walk away from.
the fenders were replaced and resprayed
the door jambs were replaced and resprayed
the little spot were the bumper meets the body still has a little spot of rust
there's a little bubling on the passenger side under the plastic piece
under the carpet by the battery it appears some rust was repaired
but, the car ran and drove better than anything i had driven and was in the best condition(minus the rust) that i could afford. i was looking for a 10k SC and the fact that this one only had 56k miles when i got it made it worth the "rusty" history.
did i make the wrong choice? I'll never know. I now own a car that i drive every day, love, and if a shopping cart dents my fender i can shrug it off and say "Oh well, the paints not original anyway".
My .02 cents is that you need to look at a car as a whole. if repairing the two rusts spots you show costs you 600 bucks, it's better than having a car with a crap tranny that'll cost you 3500.
http://www.mindspring.com/~tom_brown/silver911side.jpg
ASD 10-07-2004 10:49 AM
I would get under the car and look at everything for evidence of rust. The spots in the photo look like rust from the outside going in, possibly as they are not bubbling out. This is just an educated guess from the photo.
In any event I agree wiht the poster who said take the car as a whole, and see if it stacks up. Mechanicals, interior, all together.
aigel 10-07-2004 11:15 AM
Don't walk, RUN! I would never consider an SC with even a spec of rust. There is no need to even bother, as others have said, there is plenty of completely rust free examples out there and they are not any more expensive than what you are looking at here. It is impossible that this car has only been in TX, unless it sat through every Amarillo winter, right in a salt pile. Rust this bad is an indication that the car has been beat around and not cared for at all.
George
Tim K 10-07-2004 01:15 PM
"It is impossible that this car has only been in TX...."
I've got the CARFAX info, and it appears that it spent its whole life there.
Tim K
Joeaksa 10-07-2004 04:17 PM
Please do not forget that a Texas car can be from the Gulf area and could have been in the ocean/salt spray for a long time. My 911 was sold in Austin and moved to McAllen TX entire life and not a spot of rust but I checked it over very well before buying it.
Also any metal that has been repaired or welded will have the zinc coating removed, which usually allows rust to form if the surface is not prepared properly.
JoeA
Aussie 10-07-2004 04:56 PM
[My .02 cents is that you need to look at a car as a whole. if repairing the two rusts spots you show costs you 600 bucks, it's better than having a car with a crap tranny that'll cost you 3500.
Yes but usually after you fix the two rust spots you will often find that they were the tip of the iceburg and whole life of the car you find rust spots breaking through in other areas.
Being from Canada snow and salt on the roads is a cocktail for rust especially the underside of the car and wheel well areas, which are often very expensive to fix.
I know if i lived in Canada I would be taking a drive down to California and make it a mission to by a car from that area, of low humidity and rain fall.
A crappy transmission will be cheap compared to fixing lots of bodywork.
Being a cheaper car to buy will often work out far more expensive in the long run.
