Guest
Posts: n/a
I just picked up a set of16" by 8" and 9" BBS rs three piece wheels. One of the wheel halves was majorly curbed and bent.
Who sells these wheel halves? Is this a repair I can do myself? I'm assuming it only involves unbolting the halves and replacing the bad half with a new gasket and sealant. Anybody have any experience with this? Thanks in advance. Ted Thomas NoVa Dorki |
It depends on what wheels you have. BBS discontinued some of their 16" halves a while ago. Try Bob Woodman tires. They have a large selection of used ones. You will need a new sealing kit as well. I also run a bead of silicone around the joint after the wheel is assembled as an extra precaution
http://www.bobwoodmantires.com Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
My Gottis supposedly use stretch bolts which are good for one time use. You also have to be sure that the bolts are torqued very evenly.
Warren & Ron, may you rest in Peace. |
Super Moderator
Bob Woodman took care of me. Great service!!!
