Send a message via AIM to Tommy B
Sunroof problems
the sunroof on my 80 SC is slow closing right now and gets stuck. It closes crooked sometimes and jambs.
Do i need cables or a new motor? how can i diagnos the problem without buying the wrong replacement parts?
80 911 - First P-car....
Old 10-11-2004, 08:04 AM
zotman72's Avatar
Well there are all sorts of posts here on the subject as well as Wayne's book which will help you fix most common problems. Sounds like your problem is a broken cable or plastic slider pin holder. I got into mine ('80SC) last month and realized that sunroof elements are relatively simple, however some hoser had gone before working on my sunroof and I had mismatched parts. I bagged the job and gave it to a local Porsche shop that fixes 30-40 sunroofs a year. $700 lighter, the roof works like a charm. YMMV
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 10-11-2004, 08:28 AM
Originally posted by zotman72
Wayne's book will help you fix most common problems.
ditto
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-11-2004, 09:20 AM
youngkang's Avatar
Mine jams and go croocked also. If you find out what the problem is do you mine sharing hopefully with pictures?!
86' 930 red "Wild @ss Hotrod" Thanks John
Old 10-11-2004, 09:52 AM
oops i guess i should dust of the old 101 projects book that' s been sitting on my coffee table for 6 months now.
sorry for wasting bandwidth
Old 10-11-2004, 10:58 AM
gregk1's Avatar
I just fixed the guy next doors sunroof last week if your cables are ok witch you need to find out, they have to be in time with each other most of the time there is a little bolt that comes loose and the cables get out of time, if the roof doesn't heel up in the rear to sit flush with the rest of the roof then most likely the bolt has come loose, if your lucky the parts may be sitting up in the roof where the panel retracts in to, if they are not they are a little hard to find, to get to the inside of the roof the headliner just pops out across the front and slides back then you can see what your problem is, once you get the cables reatched to the roof you time the cables by removing the drive part of the motor, push the sun roof closed then reinstall the drive and it should work, some times a little slow but with a little help it works fine
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 10-12-2004, 06:37 AM
