				Update: Ignitioneering
			Anyone have any experience with  Ignitioneering? I need my disributor re-curved and got a recomendation to the shop from a muscle car guy. I called and they work on Bosch distributors, have a 3-4 hour turn time and only charge $30-$50. So far so good, just looking for others opinions.
				Thanks in advance!
			68 911L Last edited by B D; 10-06-2004 at 01:42 PM..  |
			Bump
			Curious if this shop should go on my "list".
	Warren & Ron, may you rest in Peace.  |
			if it's old enough for a recurve it may be old enough for a rebuild
	Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6  |
	68 911L  |
 JCM
	Stuff of marginal consequence: - 1974 911"Carerra" sunroof coupe  |
			Thanks Jason for checking on this. I've talked to Henry about this and the price and turnaround was lets just say diffrent. No knock to Henry it's probably just to small of a job for a busy shop.
	68 911L  |
			Got my distributor back to day, turnaround was only four hours but I did not want to sit on the freeway during rush hour to pick it up yesterday. Everything checked out fine it just needed a recurve. I would highly reccomend the shop, FYI the shop is also known as Orange County Speed. I actaully used the shop before when they extended a magnecor coil wire for me free of charge a few months back.
	68 911L  |
			 I would rather be driving
			What did they do for a recurve?  Was the curve modified?  new springs?  Weights?  did you supply them with an advance curve to go by?
			I am just curious what they can do. I am thinking about having my SC dist recurved to match the carbs and cams in an upcoming engine project.
	Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks  |
 Price was $30 for labor and $5 for parts. I am sure they can help you modify a curve for a specific use like street or track if needed. I would first try to get specs from others who have done some dyno time and played with the curves on a similar set up.
	68 911L  |
			I will likely follow an early profile on the advance.  As Ronin said, the 2.7 is a good one.  Its just nice knowing there are shops that can do this for a reasonable price.  $500 is not a reasonable price to me.
 I spent the less than $300 for new 'cause my orig had over 100k mi on it and didn't want to worry about a future rebuild.. so now I have a decent spare if needed. I'm not a good example on what you should do. I also have 2 functional spare alternators and 2 functional spare fuel pumps.
