FunWithMy911's Avatar
Question One last attempt; Help me please, Control plug a mess
I have been hunting down a boost pressure guage problem and found a broken wire in the control plug area. I didn't take enough care with this and all the pins have come out. I have no idea which one goes where! The holes are numbered 1 - 14 could someone please please tell me which colours go where or send me a wire diagram.
(1988 930 Coupe)
Old 10-10-2004, 01:23 PM
What freekin Oil Leak?
TurboBert's Avatar
Assuming the wiring is the same as a '78 930, then it's:
Pin-wire color
01-Yellow
02-Red
03-Green/Back
04-Green/Brown
05-Green/Yellow
06-Brown/Gray
07-White
08- Brown/Black
09-Green/White
10-Red/White
11-Blue
12-blank
13-Brown/White
14-Black/Purple and Red (two wires)
You may want to have this confirmed before you use this information.
'79 930 US
Old 10-10-2004, 02:33 PM
Thanks much appreciated, if anyone else can confirm I would be very greatful
(1988 930 Coupe)
Old 10-10-2004, 02:39 PM
Hi Guys, Thanks to TurboBert some of the colours match, but I'm still not quite there, please I know this is a ball ache to check out, but I'm desperate to fix this up, could someone with a 911 from 83-89 preferably a Turbo, check these colours. Your help is much appreciated.
Richard
(1988 930 Coupe)
Old 10-11-2004, 07:47 AM
the ends pretty much keep their position, out of the plug, as long as you don't twist them around, so they should still be in order.
206 637 4071
Old 10-11-2004, 09:06 AM
Hi John thanks for your input, yes I agree with you, with that and the simalarities TurboBert gave me, I've pieced it together; but it now doesn't start! Absolutely no power to the coil. So to rule out absolutely the plug I wanted to make 110% sure, before looking elsewhere. If I put a volt meter from the male, to the female with ignition on, would you expect all pins to show a reading?
By the way good luck with the Bus stop issue, keep us informed.
(1988 930 Coupe)
Old 10-11-2004, 01:13 PM
you won't find much power to the coil because it's a CD system. checking voltage with a test light is not a good idea around electronics like the CD unit. use a digital volt meter. check power at the red wire going into the CD unit. that can be done with a test light. while you were in there fixing the plug, you may have dislodged the over-rev cutoff relay, that yellow one, just above the plug. if it breaks it's connection, the pumps won't run.
206 637 4071
Old 10-11-2004, 01:22 PM
Cheers John, will go check now, your prompt reply is much appreciated. Have to turn flood lights on out the back, as it pitch black here now!
(1988 930 Coupe)
Old 10-11-2004, 01:27 PM
Hi, Well progressed a little further, did the light test on the Red/White wire leading into the CD box and lit up when ignition was on, CD box whining away too. I then checked with a digital volt meter the brown/white and white wires on the coil - Nothing, But when brown/white and side of car there seemed something at first full votage but then only 2-3 Volts, the white wire to the car was nothing? What voltage would you expect across the coil? Would the immobilizer affect it?
The over-rev cutoff relay above the plug was fine.
Any more suggestions taken willingly.
(1988 930 Coupe)
Old 10-11-2004, 02:45 PM
you probably have spark if the CD whines. probably, so check the fuel pump fuse. 6th fuse from the windshield forward. also you should feel a vibration when the pumps run. have someone crank the key while you feel the rear pump, which is easier than the front one to get at. car in neutral please.
206 637 4071
Old 10-11-2004, 04:29 PM
