Wow, $14 bump steer kit is amazing
I used to have some really bad bump steer to where if I hit a bump it would almost take the wheel out of my hands. I just got done installing the $14 bump steer kit from our host and its awesome. I was a little skeptical because I figured nothign could be fixed for $14 but it is awesome. It doesn't have any bump steer left and it only took me about 1.5 hours to install.
I would highly recommend it.
Currently own: 1980 911SC slantnose 1991 Honda Accord -daily driver (1991 Honda Accord #2 - just because) 2003 Acura TL Type-S (2006 Honda Odyssey w/ DVD) Gone but missed: 1988 Mazda RX-7 Turbo II (1991 Jeep Wrangler Renegade) 1984 Jeep CJ-7 (1994 Chevy Blazer) 1987 Chevy Corvette (1996 Mustang Cobra) 1993 Jeep Wrangler (1995 Mustang GT Conv.) 2003 Ford Explorer Sport Trac (1987 BMW M6) Future: Hopefully not too far off Ferrari Testarossa (Lamboghini Diablo or Countach) Detomaso Pantera |
What's the difference between the $14 kit and the $300 ~ $500+ kits? (And don't say "About $250.00").
The $14 kit is nothing more than spacers for the steering rack. The $3-500 kits go between the steering knuckle and your tie rod.
ßrandon |
Driving member
Most of the more expensive kits are adjustable as well.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
do your tires rub? will this help that pesky problem? look in your ups box today for the belts.
Any other difference on the steering wheel feeling, Do you notice the difference ONLY when hitting a bump?
The $14 bump steer kit is good quality I can't deny that. It worked well for me too. But if you ever have problems with installation or questions while installing it you might as well have a beer and talk to the wall. I'm not just talking about this kit either. In my LIMITED experience with Weltmeister, their customer service/support was horrible! With me anyways. Results may vary. I won't go in to details, but if I can avoid, which shouldn't be hard to do, Weltmeister products in the future. I will.
Bill 997.2 |
Re: Wow, $14 bump steer kit is amazing
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
I've had similar problems with Weltmeister. If everthing works you're fine. Any problems and they can't help. they did though help me source the plastic covers for the rear sping plates. What was amazing was that they had none it stock. I susupect they don't make a thing on their own.
The good part is the price. The bad part is that it's usually a primitive solution to a problem. Just compare their Weltmeister bars to some of the new products on the market. A whole world of difference. Weltmeister is the Target of Porsche parts. If you want Armani you have to find a different source. Richard Newton |
I dont knwo the difference as far as feel between a $300 kit and the $14 kit but I use my car on the street and the price on the $14 kit was right. I figured if it did not work then its not much of a loss in the wallet.
The steering feels tighter because before it would wobble over bumps or uneven pavement so it seemed like I was always getting a bit of a vibration but now it is solid and firm. I would have to rate my mechanical ability as a solid 3 on the "101 Things" scale. It took me a lttle over an hour but was not difficult. It would have taken me less time but I had to disconnect my amps and capacitor that reside under the hood on top of the smugglers box. This alone took me 20-30 minutes to do. All in all it was a very easy install.
This is what the high-dollar kit looks like:
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
How are you guys measuring bump steer? I usually remove the sping so the lover control arm can make the full arc. What are you guys doing to get the bump steer correct?
Richard |
The amount you lower the car determines what you do to re-establish a decent suspension geometry. If it is lowered just a bit - say for street use - then all you want to do is the spacers (fat washers). If it is lowered a lot, then you need to move the spindles. Search for more info - it's been discussed in detail. Last edited by randywebb; 08-11-2006 at 01:23 PM.. |
Back in New England!
Slantnose,
Can you post a pic of the $14 kit after install. That will let us compare its looks to the $300 widebody 911 posted. Thanks, Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Matt,
you can't really see the 14$ kit after install it goes between the chassis and the suspension cross brace. so its covered/hidden after installed. picture about 8washers in a stack with a longer bolt. brant
When I installed the steering rack spacer, it raised my front end a bit. Did you have the same experience?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Check this link out. Some of you may be actually making the bump steer worse.
http://www.stockcarproducts.com/tech1n.htm Richard |
95% of my bump steer was cured with the cheapo kit from PP. Took me a couple of hours then had to have my mechanic do a quick front end alignment.
1982 SC...Guards Red + Linen |
I can't believe we're "into" this thread for this amount of time and number of responses....and we still haven't answered the basics.
Assuming for the moment that Euro ride height is ideal as it pertains to bump steer ( it isn't...but it's close)...let's go from there. The $14 bump steer kit is simply a set of washers and longer bolts. If you happen to be lucky enough to lower the car the exact amount of the washer thickness ( below Euro height)....you then re-establish the "goodness" you had before you lowered. The goal is to get the steering arms as parallel to horizontal as you can get, as this imparts the least amount of "horizontal" motion deviation with a bump. The washers are only about 12-14 mm thick, so lowering 1/2" is all she wrote as to maintaining this goodness. If you go lower, you will start deviating from "goodness" since there is only so much space for the washers and thicker washers don't fit the allowable space. THAT's where the spendy bump steer kits really shine. Fine adjustability in a broader range of applications ( ride heights). Plus..if you remember...I said the Euro height was assumed to be nearly perfect. It is actually not that. The spendy kits even allow you to fine tune at Euro height...but many people would not take the time to tune properly, as it it's an involved process with small adjustments. - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
"95% of my bump steer was cured with the cheapo kit from PP."
Bump steer is excessive toe change as the suspension moves - not ideal for cornering. That the $14 kit reduced the steering kickback was secondary (but no less important). One can only approximate true bump steer correction with these spacers. Richard provided a good link explaining what it is and how to propertly measure it. Only after measuring it can one fully correct it, but this is more of a must requirement for a track car than for the street. Sherwood |
