How much gas do I have?
When the gas gauge hits "R" is that the equivalent of empty or is empty by that green spot below R? I dont feel like testing how far it will go!
Alexander '75 911S Targa '86 951 SOLD |
RETIRED
Go for a drive with a gas can...run out and deal with it....
Problem is, most tanks have a lot of crap in the bottom. Be prepared for a clogged filter or worse. Personally, I would just fill it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Make Bruins Great Again
Although it is nice to know if your gas gauge is accurate or not (as in how badly do I panic if I realize that I'm out?), I'm with Mikez-too much junk in the bottom of the tank. I guess you could go for a drive with a gas can AND a new fuel filter....
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
So does R=empty?
R stands for reserve. Bad advice to do the experiment. Do not run out of gas; besides debris in the fuel clogging the filter, this can also burn up the fuel pump as it requires fuel flowing through it for cooling. Jim
Go Speedracer, go!
R=reserve I believe. When the car was new, I'm sure you could depend on that reserve amount of fuel being consistant. Since the car is now 20+ years old, the fuel level sending unit might not be as acurate as when new, and as others mentioned there could be gunk in the tank throwing it off.
1981 SC ROW Coupe |
i refuel usually when the light comes on, and the pump stops at around 18.5 gallons. that means that there are at least 2-3 gallons left when that light comes on since my SC has a ~21 gallon tank. I would agree that it is wise to not test the bottom of that old gas tank and take the light to mean that you should refuel as soon as possible.
__jfw834__ '90 C2 Cab - '12 Challenger RT "A woman is only a woman, but a car is an A-U-T-O-M-O-B-I-L-E!" |
RETIRED
Open the bunghole where the sender and suck all the crud out....change out the filter(s) and then try it....
Drain the tank into a clean fuel can. Use a funnel and filter. Then put exactly 1 gallon in. Look at the gage. Go to two gallons, etc. Nice project which can take as much as an hour on a nice day. Then you know exactly.
Old Tee all 911s sold |
On my '88 the reserve was about 2 gal.
I think my owner's manual says 1.5 gallons.
"left the electrics on for a minute or more without fuel". People do this, especially if they do not know they've run out of fuel or the airflow switch has been disconnected or is malfunctioning. Then the fuel pump will continue to run if the ignition key is in the "on or run" position even if the engine isn't running or turning over. My position remains the same; delibrately running a CIS system out of fuel is an unwise and unnecessary thing to do. Cheers, Jim
Maybe I have a noisy fuel pump, but I certainly would turn the ignition off if the engine was off.
Of course, going by the title of the thread, the correct answer is, how much cabbage/beans did you eat?
Registered abUser
My low level gas light comes on and goes off depending on travel and fuel slosh. Once it stays lit. It is time to find a pump pronto. |
RETIRED
He!!....my Blown Dodge gets 8.5 mpg in town....time to find a suck.....er, buyer....
