-   -   Someone plz check rear wiper wire color sequence? (http://forums.pelicanparts.com/porsche-911-technical-forum/186479-someone-plz-check-rear-wiper-wire-color-sequence.html)
Bob Prosser 10-10-2004 02:27 PM
Re '89 Carrera rear wiper.
Can someone help me out, please. I need to verify the color sequence of wires that plug into the rear wiper motor. See, I had my whale tail repainted recently. The shop seems to have messed things up while reinstalling the engine lid because now the wiper does not return to its upright position. It just stops wherever I turn it off.
I have looked everything over closely. The reset mechanism -- the points that open and close -- look to be operating as they should, at least physically.
Thought I'd check the wiring. Presently, I have this sequence, going from the front to the back (in line with the car's direction of motion):
1.) Connect 53 -- red w/black stripe
2.) Connect 31b -- brown w/white stripe
3.) Connect 53a -- red wire
4.) Connect 31 -- brown wire
Any ideas? Thanks a million.
Por_sha911 10-10-2004 08:44 PM
On the `87 as it was being removed:
http://forums.pelicanparts.com/uploa...1097466219.jpg
Bob Prosser 10-11-2004 09:18 AM
Joe, thanks.
It's hard to tell for 100% sure, but it looks like that far left red wire has a black stripe ? If so, my wiring is correct.
http://forums.pelicanparts.com/uploa...1097511168.jpg
4.) Connect 31 -- brown wire (ground)
Can anyone check their shop manual to see if those connects match up?
Also, there is a small wire inside the cover cap that connects to one side of the armature. It seems to be powered because if I pull it off, the motor will not run.
I guess I need to find a wiring shematic to check power to each wire.
kees 10-11-2004 09:56 AM
rear wiper
http://forums.pelicanparts.com/uploa...1097513508.jpg
http://forums.pelicanparts.com/uploa...1097513737.jpg
Picture rear wiper motor 1985
SmileWavy
Kees.
Bob Prosser 10-11-2004 12:51 PM
AH HA! From the diagram, I see there are TWO power inputs. I had checked the 25 amp fuse in the front, but did not think to check for another power circuit in the engine bay. DOH! I just did. Yup, it was blown. New fuse ... end of problem. Gentlemen, I owe you a beer. THANK YOU!
galwaytt 02-21-2005 05:00 AM
rear wiper motor.......more...
just a small bump on this, as you gents are likely to be familiar with the circuit - anyone else - please chip in!
The rear wiper hasn't worked on my car since I got it, 12mths ago. Pulling in to the car park at work on Friday, I notice in the rear view mirror, that the wiper is working !! One of the kids must have been at the switch. Anyhoo, park the car, but the motor hasn't twitched since.
I opened it up last night, and found one broken wire on the armature, but even patching that, it still wouldn't work. However, if I squeeze the contacts together, it runs !! See here
Question is, what is the normal situation for these contacts? Closed/Open, or what.....? Any info on re-furbing it would be appreciated.
http://homepage.eircom.net/~moylan/rear wiper motor.JPG
kees 02-21-2005 05:52 AM
rear wiper motor
Hi John,
Two pictures of my spare rear wiper motor.
When I'm back from work I can send you some pics with the rear wiper motor in the car.
http://forums.pelicanparts.com/uploa...1108993880.jpg
http://forums.pelicanparts.com/uploa...1108993923.jpg
SmileWavy
Kees.
galwaytt 02-21-2005 05:59 AM
dank je vel !! (I think I've got that right...........)
It looks like contacts 'normally' closed?
kees 02-21-2005 06:10 AM
rear wiper motor
Hi John,
My pleasure. The contacts are 'normally'closed (wires are not attached).
The contacts in the car (wires attached) are also 'normally' closed (just checked it).
SmileWavy
Kees.
BTW: You were almost right, it's "dank je wel".
Upier 07-16-2015 07:29 AM
Bump
