-   -   Custom 2.7 Turbo Problems (http://forums.pelicanparts.com/porsche-911-technical-forum/186659-custom-2-7-turbo-problems.html)
sammyg2 10-13-2004 07:31 AM
Some turbos actually have true mechanical seals that will hold back full oil pressure.
I ran a garrett on a 914 I built in a pull through application (turbo was after a carburetor and before the engine). In that application a mechanical seal was manditory because the turbo saw full manifold vacuum when the throttle was closed.
A turbo like that would actually be better on a 911 but the piston ring type will also work as long as the oil is drained away fast enough to prevent a level from building up in the drain section.
ssetek 10-13-2004 11:20 AM
Originally posted by RickM
Perhaps a dumb question: Would it be feasible to plump a guage to monitor pressure? Maybe an adjustable valve/restrictor as well?
yes you can, i used a gauge on the inlets of the turbo when drilling custom restrictors to monitor the pressure.
audi2.7t 10-16-2004 06:54 AM
This may be so simple that it's rediculous BUT I was having the same problem with my 3.2 with stage 1 ,so much smoke that the neighbors were laughing !! ,it had been standing for almost 3 years so I was convinced that turbo ,valve guides/seals ,oil rings were all shot.........on the advice of a few of the people here ,I dropped 1.5 qts of oil from the tank and VOILA....not a drop of smoke.......my oil return is also gravity with very little height difference.
Sam.
