Rear Caliper removal Quick Help
Is there a special tool used to remove the lower caliper bolt??
Old 10-15-2004, 08:56 AM
Friend of Warren
No
Kurt V
Old 10-15-2004, 08:57 AM
Your kidding right there is no room for a 19mm rench to get in there and my shortest socket goes on but no room for the rachet 82sc what the F***
Old 10-15-2004, 09:02 AM
Early_S_Man's Avatar
Porsche Crest
Combo 19 mm or 3/4" wrench with flex-socket ...
or, 3/8" drive flex handle -- mini-breaker bar
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-15-2004, 09:13 AM
I would rather be driving
jpnovak's Avatar
buy another 19mm socket and cut it off so that it only has a depth equal to the head of the bolt. It will then fit. You can also fit some of the self ratcheting box wrenches in ther. The cut socket works the best for me. It helps to get the slimest head that you can find.
Old 10-15-2004, 09:15 AM
creaturecat's Avatar
6 point 19mm socket with 3/8 flex head does the job - patience is the key when using a wrench
OK thanks but what is a FLEX socket? A cut off 19mm socket may work I just barley got the 3/4" wrench on it and broke it loose but now I cant possition the wrench for another turn THANKS again Speedy1 How short is your 19mm socket?
Old 10-15-2004, 09:18 AM
Porsche Crest
www.metricmcc.com
Warren Hall, Jr.
Old 10-15-2004, 09:30 AM
MBruns for President
JeremyD's Avatar
I used a stubby wrench - try upgrading to 933 calipers with even less room! HAHA I have three rachets and only one worked - it had a narrow head and narrow throat.
Old 10-15-2004, 09:33 AM
Hi Speedy1,
I used a 3/8" drive rachet and the regular 19mm (3/8" drive) socket from my Craftsman tool set I had. This will fit. I took a short length of pipe to make my own breaker bar. If desired the craftsman 3/8" drive mini breaker bar ( I think it is 10") with the same regular 19mm socket has the same depth too. I made some comparative measurements at Sears before I started my brake project a few weeks ago.
Good luck! Hope this helps!!
Quincy
Quincy
Fountain Valley, CA
'83 SC, '13 P-GTS
"Air cooled, fountain pen guy, living in a water cooled, iPhone world"
Old 10-15-2004, 12:26 PM
Fit box end wrench over the bolt head (preferably 6-pt.) and smack the end of the wrench with a deadblow hammer. Same effect as an impact gun. Remember, lefty-loosey (that's CC). Reinstall with anti-seize on the threads.
Sherwood
Old 10-15-2004, 01:10 PM
I was able to use a box end wrench... maybe 1/8th turn at a time. It was slooooooow going. Get one of those beer helmets and suck a few down while you're at it.
Old 10-15-2004, 01:19 PM
TCB TCB is offline
TCB's Avatar
That's pretty funny
Old 10-15-2004, 06:19 PM
Rear calipers
Success thanks all for the help actually beer helped being a thinking man I thought simple and got it from the bottom. I guess that is what I get for working on it before beer thirty!! Ha Ha thanks again for all the help!! And it was slow and go they had been removed before and there was anti seize on the threads. The leaking one took 25 mimics the other took 2. Fast easy simple!!
Speedy1
Old 10-15-2004, 10:37 PM
ipapilot's Avatar
I ended up buying some offset wrenches for the job. Good excuse to add to the toolbox...
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 10-16-2004, 06:40 AM
Here's the answer - after sending a lot time being frustrated.
Go to Sears and get a 19mm/17mm OFFSET boxend wrench. It should fit right in there. It may be too long to get it long twists on it. What I did then, was cut the 17mm end off. This enabled me to put the end of another boxend wrench on it when tightening it down. Good luck!
Morale: frustration breeds invention.
Old 10-16-2004, 06:58 AM
