slater's Avatar
Question Tach question- 4cyl to 6cyl
Provided it is hooked up correctly, would a tach from a 4cyl engine work with a 6cyl engine? Would it read incorrectly, or would it not read at all? Thanks
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 10-11-2004, 02:40 PM
I would rather be driving
jpnovak's Avatar
It will not read correctly. The trigger will count the wrong number of pulses for integration.
Old 10-11-2004, 02:50 PM
slater's Avatar
But mine is not even twitching... so I guess I will have to assume I have a bad tach or it is hooked up incorrectly. I need to get it recalibrated, but for now I just wanted to hook everything up. Thanks!
Old 10-11-2004, 06:11 PM
Early_S_Man's Avatar
Porsche Crest
Slater,
Do you have the tach trigger lead hooked up to the points, or input terminal 'C' of the CDI unit?
Your tach will read 33% higher than a 6-cyl tach at a given engine speed ... if functioning properly!
Here is a calibrator circuit that can be built from junk box parts, or less than $20 from Radio Shack ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-11-2004, 07:18 PM
slater's Avatar
Warren - You are the man! I currently have the trigger wire hooked up to the points. I have not tried hooking it up the "C" on the CDI. I have also not yet tried cleaning all of the terminals on the back of the tach, I will try that next. Thanks for the diagram, saves me from sending it off to have done! Thanks again!
Old 10-11-2004, 08:24 PM
