-   -   Using Gunson CO Tester (http://forums.pelicanparts.com/porsche-911-technical-forum/186842-using-gunson-co-tester.html)
randyrap 10-12-2004 03:02 PM
I recently purchased a Gunson CO tester and want to make sure I'm using it properly for testing my 83 911SC. The Cat has been replaced with a by-pass pipe.
JW says the optimum CO should be 3.5. Is this at idle or at a certain RPM. Should the test be done at idle? How about the O2 sensor? Should it be disconnected?
Thanks in advance ............................... Randy
walt 10-12-2004 03:20 PM
I set mine at 3.5% at idle. I do not run an O2 sensor.
VaSteve 10-12-2004 04:49 PM
You will also need a 1/4" outer diameter tube to get into the cat bung. I went to Home Depot and found some copper ice maker tubing that worked great.
randyrap 10-12-2004 07:28 PM
No need for the extra tube as I replaced the Cat with a by-pass. Readings can be taken directly within the tail pipe.
Randy
Lorenfb 10-13-2004 12:09 AM
Set the CO at about 1.5 to 2.0% before the CAT without the O2 sensor connected
with the RPM at 2000 to 2500. The 3.5% is a little too rich for the SC with CIS
injection.
