-   -   Torsion bar splines 40/44 formula? (http://forums.pelicanparts.com/porsche-911-technical-forum/186970-torsion-bar-splines-40-44-formula.html)
hkspwrsche 10-13-2004 09:38 AM
It there a formula for the amount of lowering you will get for one spline diff on the outer compared to one on the inner. For incremental changes is there a recommended difference? one down(lower) inner and two up(higher ride) on the outer for the fractional changes in ride height?
thanks,
jpnovak 10-13-2004 09:44 AM
9 deg change in spring plate for the outer splines.
8 deg 10 sec on the inner spine
50 sec difference between them should result in about 1mm change in ride height at hub.
Wil Ferch 10-13-2004 01:11 PM
I think you mean "minutes"...60 "minutes" to one "degree"
The one up/ one down difference of 50 minutes has been quoted as being something like 7-9 mm ride height difference.....not 1.
Right?
Wil :)
jpnovak 10-13-2004 01:16 PM
OOPs. Yep, calculator gives 7mm ride height assuming about 20" arc length.
Wil Ferch 10-13-2004 01:21 PM
Arc is 18.5".....yer talkin to the spring-plate-angle calculator guy...
http://tech.rennlist.com/911/pdf/settings.pdf
Wil :)
jpnovak 10-13-2004 01:48 PM
I know who did all that math. Thanks a bunch. It has been helpful many times. I just guessed at the arc-length.
Wil Ferch 10-14-2004 05:03 AM
just playin'..... :)
Wil
