aluminum rear speaker grills found
Banker on rennlist has surrounds made of aluminum exact copy of stock, and wire mesh cover slips right in perfect.
I'm not advertising just sharing, hope I did't break any rules
gratuitous shot of my amp install
Old 10-13-2004, 05:21 AM
islandflyer's Avatar
Question??
How hard was it to remove the bolts that hold the seat?
I been trying to remove mine for a few days now. I tried wd40 etx. with no luck, any sugestions........thanks!!
Jose
87 Carrera ( Nougat Brown ), 11 Subaru Legacy (daily
driver), 08 VW Passat wagon 2.0T (wife), 03 Audi A6 2.7T (sold) ), 98 Pathfinder (sold),
02 TT 225QT coupe (sold), 03 Audi A4 Avant (wife)GONE...
Old 10-13-2004, 12:15 PM
Noel's Avatar
Here are some OEM Speaker grills:
http://www.eagleday.com/911intr.html
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 10-13-2004, 12:30 PM
35 $ for a stock grill? never happen. these AL ones were cheaper.
search for seat bolts or seat removal, I'm sure theres a bunch.
only one of mine strippes out, tried the torx bit thing, didn't work.
In the end I used a chisel and BFH to get the first turn then all good. USE a very sharp chisel to get the best bite
Old 10-13-2004, 01:42 PM
DG624's Avatar
I need the covers for the side speakers on the door. The aluminum sounds like it won't break like the original plastic. I should just get new speakers.
Old 10-13-2004, 01:49 PM
