-   -   Convert a 3.0 into a 3.2 liter questions (http://forums.pelicanparts.com/porsche-911-technical-forum/187043-convert-3-0-into-3-2-liter-questions.html)
Gunter 10-13-2004 05:42 PM
Using the 98mm Max Moritz, or JE P/C, on a 3.0 liter SC engine, are the wrist pins reusable? Or do I need different ones? Other than new rings for the 98mm P/C, what else do I need to make this work?
When ordering 964 cams, or Webcams 20/21, what cam timing is to be expected with CIS? Is the cam timing provided by the supplier? SmileWavy
emcon5 10-13-2004 05:51 PM
I don't know about JE, but Mahle pistons come with wrist pins.
I timed my 964 cams per the factory 964 spec. I don't remember what it is off the top of my head, but it is probably in Wayne's book.
On a 80-82 small port SC, get your ports done, and use the early SC airbox/CIS runners. Your engine will run out of breath up top.
Tom
Bill Verburg 10-13-2004 05:56 PM
There are 3 different versions of the Mahle 98mm p/c
the 3 liter CIS version has a 22x61mm wristpin which is compatible w/ the SC con rods. These are slip fits but do need a slight chanfe on the heads cr 9.8
the 3liter MFI version has 22x58mm pins which are also compatible w/ stock SC rods, installaaton as above cr 9.8
the 98mm Motronic have a 23x58.5mm pin. installation as above cr unknown
wristpins are supplied w/ the kits usually, MAhle wil last longer than JEs,
cam specs are supplied by the manufacturer.
KobaltBlau 10-13-2004 06:41 PM
on the cams, get them from camgrinder on this board and he will help you out with things.
MotoSook 10-13-2004 06:45 PM
Andy have you bought from "camgrinder" I'm going to need some soon. E-mail me if you'd like. Thanks.
emcon5 10-13-2004 07:44 PM
"camgrinder" is John at Elgin Cams. They did my 964 grind, and are a first class operation and fairly priced.
http://www.elgincams.com/
Tom
Carrera3.5L 10-13-2004 08:41 PM
CR for the 98mm Motronic is 9.8:1 also. Actually Bill, there is one more you may have overlooked. Mahle makes/made a 98mm MFI version with 23mm wrist pins as well. CR was supposed to be 10.3:1. Andial part number was AND 103 984 SP and I don't know if it is still offered or not.
Ralph
EDIT: I take that back, I know it was offered up until a year ago because my friend is using this set in his 3.4L twin-plug.
Jeff Alton 10-13-2004 09:37 PM
Souk, i have bought from camgrinder and highly recommend him.
Jeff
MotoSook 10-14-2004 03:43 AM
Thanks guys, I had no idea "camgrinder" was with Elgin...no need to say anymore :)
Gunter 10-14-2004 10:37 AM
So, if I go with Mahle 98mm P/C, is there a seal ring between Cylinder and head just like I have now with 95mm? There is also a thin copper seal on the bottom of the 95mm Mahle Cylinders to the engine case. What seals, top and bottom of the cylinders, is used with the 98mm?
emcon5 10-14-2004 10:46 AM
No sealing ring on top of 98mm cylinders. They use the same copper base gaskets as the 95mm jugs, as they are the same size externally,
Tom
