single stage vs two stage paint
I am trying to bring my car back to it original glory. Well kind of, instead of doing artic silver I want to do continental orange. Anyways, I am going not metallic and am wondering if single stage would work. The guy at the paint shop said a lot of guys use it for older cars since it more age appropriate in some cases. Anyways, since my car is a 77 I am thinking this might be a better choice. Any reason not to? Any pictures of single step paint out there. I just picture it being less glossy but really not sure.
Any suggestions? David |
it's not as durable of 2 part paints.. spilled gas, bird $hit, etc. Single stage is also more sensitive to washing with a routine towel that slowly kills the shine. I use a chamois to wash and another to dry to prevent that from happening. An epoxy primer is nice also.
do a search for some real good info
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Friend of Warren
I have had very good luck with single stage. Shine is every bit as good as two-stage. No problems with durability either. For comparison, the ducktail in this picture I did with two-stage and the bumper with single stage. By the way got a better color match with the single stage.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Re: single stage vs two stage paint
I used single stage on my car, knowing it was going to get chipped up on the track. It's easier to repair, but doesn't have nearly the visual impact.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
two-stage gets by vote just use high quality. I find it blends easier and looks deeper in the long run and my car is black so I might be bias IMHO
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
I do not like "two stage" (base coat/clear coat) for anything. Here in AZ, the clear gets burned up fairly quickly. I like the single stage Omni paint made by PPG. This is a great product that is very durable, and easy to work with. I have used it on several jobs and have been very pleased with it.
Many people get confused when they hear single stage paint. Single stage urethane is a "two-stage" paint. It is like basecoat and clearcoat in one stage. It is acrylic urethane just like base/clear, not acrylic enamel or lacquer.
Like people above said, chip repair would be easlier with SS. BC/CC has advantages in run/dust removal after painting (especially with metalic paint.) If you are using PPG deltron, the gloss is very close between DCC SS and DBU/DCU base-clear. Many pros think base-clear is more forgiving for home painters.
Evan --------- 1987 sun roof coupe |
I am shocked by the prices on all the materials. Just the paint, primers, hardeners, reducer and clear add up to about $750. That is all top of the line 2 stage with a primer that etches and a primer that goes over that.
Unless anymore surprises pop up, this whole endevor should run me about $1,800. I suppose good for what I am getting but still alot considering I am doing 95% of the work myself. Does $50 sound high for a 3 X 4 piece of 18 guage sheet metal? David |
I have used omni and it is good and very cheap but talk to professional shops and the paint manufacturers and they will all agree that 2 stage is the better withstanding paint. Major draw back is that if its scratch's clear will have a white look to it versus a solid single stage.
Two step is easier as well to spray as you are not putting the volume on at one time and it seems to cure easier(no sagers) IMHO
That price sounds pretty fair for the metal. I found better paint job ends up better with better material I used omni, then ppgs high line then duponts high line. Hands down dupont is the way to go. I paid 200 for a gallon of appearance clear with all reducers and activators, then about 200 for a gallon of uro dupont primer(works as sealer as well and its buildable sandable) then about 90 bucks for a gallong of dupont base. Sand paper is a different story
I guess I will be using Chromobase. That's what my friend sprays in his shop. It went anywhere from $50 - 130 a quart. The self etching primer is $132 per gallon, hardener and clear combined were $100, reducer was $43 for a gallon, regular primer for over the self etching is $57 a gallon and the primer activator was $35.
How many quarts or gallons will I need of everything. I am doing everything but the floors and inside engine and hood compartments. How many quarts in a gallon. Sorry it has been a while since junior high. How much of each product do you think I will need? I think the cost just extended my project out until May 2005 vs May 2004. David |
Quantity depends on several factors, the first of which is color; it takes more paint to hide a dark color with a lighter than the other way 'round.
I bought one gallon of color (PPG CLV) which is mixed (IIRC) 2:1 with the hardener. I have maybe a pint left after subsequently painting my new fg hood, bumper and mirrors. I was painting the same color, but with a thin layer of light-colored finishing primer in between.
That seems like a lot of paint for what you did. I was told by the paint guys as probably 3 quarts paint which is added to reducer on a 1 to 1ratio making 6 quarts of spray all together.
The color is orange going on primer which I guess is can be bought with different shades (light to dark). David |
Better to have some extra sitting on the shelf for a rainy day than to be sitting there with an empty paint gun cussing at the car.
Another data point - mine is a cab, so I didn't have a roof to paint!
Two good points.
Thanks Tom. |
Chromabase is a dupont product good choice. You can save a little on primers if you use there URO buildable sandable as it works for bare metal etch/ buildable/sealer. That way only 1 gallon of primer. I would say 2 quarts of base if doing jams etc and 2 quarts of clear (3-4 coats) I am not real familer with the lower chromasystem clear but the appearance clear(high end) lays like glass. I also use a SATA gun and that may help??
Good luck
Thanks Ben.
So this primer replaces using two seperate ones? How much does one gallon cost and where do you get it? Thanks, David |
You do not have permissi
Not an auto painter, butI think the 2-stage is prefered for show-cars because there is two layers of light reflection which tricks the eyes into giving the paint "depth" without a pinpointed surface.
I think the "depth" effect can be recreated with using a color slightly inbetween the primarys(i.e a purpleish blue or a purpleish red) and a good coat of wax. Using a single-stage and sucessfully putting 5-7 run-free coats should let you color-sand all day on the flat sections regardless of the damage, and a clean and heavily waxed surface will give it enough sparkle for the bling effect. Some paints do shrink though, and a thick layer may be inclined to have problems, experience counts. Last edited by john70t; 10-14-2004 at 12:51 PM.. |
