Wiring help, please???
I just got a newer tach (I think it's a 71 or 72). It has a 7 prong outlet on the back where my old (68 911L) one had 3. Any help on on the wiring (eg, which prong is for what) would be greatly appreciated. The wiring diagrams I've seen don't seem to match this configuration.
Thanks!
'73 914-6 3.0SC '69 Jaguar XKE '05 Colorado Crew Cab |
what brand is it ??? Can you do any resistance and continuity testing with
digital meter ??? Can you a least find the ground connection ??? Trying to help. Maybe some of the outlets are double, which means 2 connectors for same usage. Trying to help. Filou. |
I've never seen a connector like that on the back of a 911 tach. Certainly not a standard 72 model. Is there a Porsche part number on it?
Tim
1986 911 Cab 2008 Audi A6 |
Exactly it. Start to look for ground with the meter placed on Ohmeter function. Any continuity between one of the prong and the housing will be the ground. Try to see if any of the others prongs have relationship between one and another. Like i said, maybe some of the prongs available are double within the same connection. So two prongs might have continuity, one with another.
Keep us posted. Filou. |
1971 tach has FOUR prongs.
On the back of the tach there should be a blue stamp with the date in a circle. Can you post a picture of the FRONT?
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Check the wiring diagram located in "Elec Diagrams" on the pelican home page.
Daniel,
That is an '84 - '89 Carrera tach ... are there any terminal numbers in the connector next to the pins??? #1 Black -- ground return/shield from DME unit #2 Black/Violet -- TD tach signal from DME unit #3 Brn/Red -- speedometer #4 Gray -- exterior lights or wiper/washer system #5 Red/Black -- switched +12 Volt power #6 Brown -- Ground #7 -- not used #8 -- not used
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Daniel,
Yes, the #2 terminal is what needs the tach signal ... hopefully the Crane unit can provide the proper signal!
