-   -   Drag/CD scenario.......a question, a challenge.. (http://forums.pelicanparts.com/porsche-911-technical-forum/187388-drag-cd-scenario-question-challenge.html)
Craig 930 RS 10-15-2004 02:56 PM
Two cars. Identical HP/TQ/gearing - everything equal incl weight.
Coefficient of drag changes.
Car 1 has a Cd of .39
Car 2 has a Cd of .29
Car 2 - with the lower CD of .29 - can top out at 190 mph.
What will car 1 top speed be - assuming top speed rpm are the same?
Trying to compile a practical, real world idea of Cd vs. top speed...
THX!
masraum 10-15-2004 03:19 PM
I think it's important to also have the frontal area, if you want to use the numbers for a 911 the '69 model had a frontal area of 1.71 m^2.
I don't think you can do the calcs without that info.
Are you saying using the same gearing on both cars or changing the gearing?
Craig 930 RS 10-15-2004 03:33 PM
Same gearing both cars.
Make the frontal area equal then? What ever works most accurately for this situation..
THEN what top speed?
Eric Coffey 10-15-2004 04:12 PM
Obviously a lot more factors to consider, but my SWAG is: 178.354mph
:D
All I (think I) know is that drag increases @ the square of speed, and power-required increases @ (roughly) the cube of speed.
masraum 10-15-2004 06:04 PM
The drag force for a given object can be found using the formula below:
FD = CD 0.5 A v2 edit crap, forgot Rho
FD = The drag force measured in N (Newton).
CD = The drag coefficient, measured in N/ m2, i.e. the drag force per square metre frontal area of the object shape. You will have to find this figure in a table. This value is usually found through (very expensive) wind tunnel measurements.
Warning: Airfoil tables frequently give the drag coefficient per square metre wing or rotor blade area, rather than per square metre frontal area. You can recalculate that figure, since you know the relative thickness of the airfoil.
= The density of the fluid measured in kg/m3. In the case of dry air at sea surface level at 15° C the figure is 1.225 kg/m3. You can find air densities for other temperatures in the Reference Manual.
A = Frontal area of the object in m2.
v = Relative wind speed in m/s, i.e. the speed of the fluid moving past the object. If the object itself is moving while facing a headwind, you have to add the headwind speed to the speed of the object to obtain v.
masraum 10-15-2004 06:16 PM
I could be wrong, but I think the way to check this would be to first determine the force that the car with the .29 Cd is exerting at 190 mph (I think you need to convert to meters per sec first which is about 84.44 mps) then once you have that force plug the force into the equation and solve for the velocity. (since I think we are assuming that at top speed both cars can exert the same force, but I think that would mean possibly either different gearing or a really flat and/or fat power curve)
OK, so
The force that the one is exerting when going 190 is
.29 * .5 * 1.225 * 1.71 * 84.44^2 which gives 2166 I think in Newtons
then solving the next equation with that number
2166 = .39 * .5 * 1.225 * 1.71 * v^2 gives the velocity as 72.81 mps, converting that to mph you get 164 mph
I wouldn't testify in a court of law, but I think that's it assuming the equation that I got off of the internet is right and the units work out correctly. I did ok in physics in school.
edit adding rho in didn't change the results.
I suppose an easier way of doing this would have been to put the two equations back to back, that way you can skip a bunch of the numbers
.29 * .5 * 1.225 * 1.71 * 84.44^2 = .39 * .5 * 1.225 * 1.71 * v^2
That would simplify to
.29 * 84.44^2 = .39 * v^2
masraum 10-15-2004 06:42 PM
One of you engineering types tell me if I get the cookie.
Actually doing it the same way with mph I get the same results which makes sense, so I'm confident that my results are correct.
1fastredsc 10-15-2004 06:57 PM
Shouldn't the 1768 representing the drag force for car B in newtons be 2166 newtons since we are assuming maximum engine force pushing the car through the air in either scenerio or am i confused?
masraum 10-15-2004 08:28 PM
Sorry, screwed up the calcs the first time, and then when I went back and editted my first post to fix my mistake I missed changing the second instance of 1768 to 2166. Yes, you are correct, it was a typo.
Randy Webb 10-15-2004 08:56 PM
I'm a scientist type, not an engineering type, but I award you the cookie (tho I didn't check the math itself). There's also the assumption involved that the engine can generate that force...
Now -- for extra credit -- what will the maximum speeds of each car be in the rain?
masraum 10-15-2004 09:37 PM
I would think that the rain drops themselves may not actually make any difference assuming we don't get hydroplaning, and the drops are not large enough and the air isn't dense enough with them to radically alter the rho, but the temp and relative humidity would probably be different than in my assumed ideal world, which would change rho which might change the calculation some. I'll say that assuming the temp is still the same and that assuming the air isn't more humid that the top speeds will be the same, but that's just a guess.
Do I now have 102 on this test? ;)
kach22i 10-15-2004 10:22 PM
15-20 years ago Porsche put in it's advertisements that they included their low frontal area in their CD calculations and that other manfacturers did not. Was that marketing hype?
Randy Webb 10-15-2004 11:42 PM
no, we reduce your score from 99 (before) to 97. Think about it - the car has to push the rain drops out of the way.....
kach - that doesn't sound right. Could they have been talking about the fact that many manfs. remove outside mirrors and trim when measuring Cd? Also, often it is measure with the wheels stationary instead of rotating, which is harder to do.
masraum 10-16-2004 12:07 AM
Well, you know, they always say you should leave your first answer. I had originally thought the water would slow things down by changing the rho, but then I thought maybe it was a trick question and changed my answer, but I still don't know by how much. I would assume that it would depend upon the size of the drops as well as the number of drops or drop density. I looked around the internet for more info, but couldn't find any. The closest I came was finding the rho of steam which is much different I assume due to the temp difference.
Randy Webb 10-16-2004 11:21 AM
I guess it is a trick question. The vehicle is now in a mixed media regime, not in a simple fluid (which is what all the fluid dynamics eqns. are based on).
Wil Ferch 10-18-2004 12:27 PM
Drag increases ( as noted) by the square of speed.
Horsepower required to acquire such speed, however, is a cubic relationship with speed.
I haven't plugged in the math, but if the frontal areas are the same, and you know the top speed of the CD.=0.29 car, you can also calculate the hp required to ge to 190 mph.
now...starting with that same hp, work backwards including a Cd of 0.39 and double check drag being proportional to v2.....hp proportional to v3...and see if you come up with the same answer....
Wil
Craig 930 RS 10-18-2004 01:00 PM
Can you show us the math needed (& or HP) for the .39 car to go 160, 170, 180 mph? My car has 330hp now.
THX all,
kach22i 10-18-2004 01:44 PM
Click on the 4th from the bottom, it says Audi TT, but it's about the 911. Go aerocrazy.
http://www.google.com/search?q=early+rear+spoiler+porsche+development&hl =en&lr=&start=10&sa=N
Craig 930 RS 10-18-2004 02:16 PM
GREAT STUFF!
The Rosetta stone ;-)
Thanks KACH & all -
limble 03-01-2005 07:26 PM
How does this equate to horsepower?
patkeefe 03-01-2005 07:31 PM
Steve:
The batteries are dead in my HP calculator, but I have another one at work. I believe you get your choice of chocolate chip or oatmeal raisin.
Pat
masraum 03-01-2005 10:08 PM
Thanks!
masraum 03-01-2005 10:12 PM
Oops, sorry, chocolate chip.
PS I'm taking a class this semester called aerodynamics. It's a pretty basic course that is actually part of a flight training program, but it sounded interesting to me. I've learned a lot of interesting stuff.
For instance, the question about driving in rain earlier. I believe Randy about rain making it worse to drive through, but.... I've learned that humid air is actually less dense than dry air because the water vapor is lighter than air and displaced air, so it's like being at a higher altitude or in hotter weather.
MuffinMan 03-02-2005 06:04 AM
Porsche offered a turbo-bodied version of the Carrera in the late 80's. It had the running gear of the Carrera but the bodywork of the turbo. I don't know the cD difference between the two, but I do recall the top speed on the turbo-bodied version was supposedly 12mph lower then the standard Carrera body. Does anyone else remember reading this fact? I'll see if I can dig up my resource...
masraum 03-02-2005 10:29 AM
I hadn't heard what the difference was, but it is true that the turbo has a larger frontal area and possibly a worse Cd which makes it harder to go faster. That's why the Ruf Yellowbird used the regular Carrera body instead of the turbo body. If the flag mirrors reduce top speed by 5 mph, I can see how that fat booty from the turbo could do 12.
randywebb 03-02-2005 11:57 AM
Steve - post any good diagrams from your lectures.
Enjoy the course.
beepbeep 03-02-2005 12:05 PM
CD * frontal area = drag force
(drag) force per second = HP
You cannot calculate max speed or drag force without knowing frontal area. A jumbo jet has lower CD than your car but much higher drag force.
Also, you cannot calculate max speed without knowing gearing either, unless you have CVT.
I can embellish this with actuall formulas later, but you get the point:
1 Watt = 1 Joule per second
1 Joule = 1 Newton per meter
1kW = 1000W = 1.36 HP
rdane 06-20-2005 10:17 AM
anyone still have this link?
Can you send me to it?
911teo 06-20-2005 10:28 AM
me too...
