Randy Webb's Avatar
differential removal
Anybody have a detailed procedure to remove the differential from a 901 trans.?
Old 10-17-2004, 10:22 PM
separate the CVs from the flanges, remove both flanges, remove side cover and lift out ring gear/diff. can be done in the car.
206 637 4071
Old 10-17-2004, 10:26 PM
Randy Webb's Avatar
Good news - thanks!
And I don't have to align anything or adjust anything on re-assy? Just slide the ring gear/diff. back in?
Old 10-17-2004, 11:22 PM
jluetjen's Avatar
Remove the CV flange bolt on the diff cover side first and check it for a teat at the end. If the that CV bolt has a teat on it, do not remove the second one until you remove the diff cover and then reinstall the CV flange along with the bolt. Then go around and do the other side.
Why: If the diff is the style in which the spyder gears are held in place by the teats on the bolt, and if you remove both of the bolts, you'll end up having the spider gears getting all out of alignment which is a real PIA to fix.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 10-18-2004, 03:25 AM
