DIY shift coupler pic
so i go into the machine shop at work intending to make some brass bushings for my coupler. then i see this nice aluminum rod...and a mere 5 hours later, i emerge with an complete custom made universal joint style coupler. Its dead solid, no play at all. hope it works well...
jason
motors: 73.5 911 T targa - RIP, 2005 Subaru Legacy 2.5i
pedals: Ellsworth Truth, Neuvation road bike
Paddles: Dagger Ego
Wind: Liquid Force kites/Ocean Rodeo Mako board
Old 10-18-2004, 10:11 PM
3.2 CAB's Avatar
Looks great, are you going to spline the shaft? Keep us posted on how well it works, and if any problems come up. Do you know what grade aluminum it was? Again, WAY TO GO.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-18-2004, 10:20 PM
I gotta respect the effort.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-18-2004, 11:49 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Very nice work Jason!
Now figure out how you can make them cheap for the rest of us.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 10-19-2004, 12:40 AM
Porsche................more than a car..............more than a hobby.....................it's your life now.
Nice work, but now eveyones going to want one.
Old 10-19-2004, 05:55 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Slick!!
Very nicely done.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 10-19-2004, 06:26 AM
19 years and 17k posts...
azasadny's Avatar
Great job! You're very skilled!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-19-2004, 07:59 AM
youngkang's Avatar
Nice job. Now, I want one.
86' 930 red "Wild @ss Hotrod" Thanks John
Old 10-19-2004, 08:10 AM
MAGA
Tim Hancock's Avatar
Anyone can buy a car, but not everyone can build one. Good job!
(those pivot pins look a little small and you may end up with some play over time due to a lack of suface brg area but who knows it may hold up just fine and if not it looks like you surely have the skills to tweak the design a little)
The satisfaction acquired by doing it yourself cannot be denied!
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-19-2004, 08:20 AM
Excellent work, bet you can get some precise shifts with that.
Nathan
78 911SC
Old 10-19-2004, 09:46 AM
I got the coupler installed tonite and took a quick drive.
I replaced 30 yr old oblong bushings with new round hole bushings in the stock couple about 750 miles ago., so i have recent history.
here's my rating so people can get a feel for the relative improvement:
ratty old worn out oval bushings=5/10
new round bushings=8.5/10
new universal joint=10/10
where 10=the best i have felt my 150k transmission shift, your milage may vary.
It feels similar in precision to the round plastic bushings when it comes to finding the gear, but it is smoother engaging the syncros. This is probably because all the shifter force is transmitted strainght thru the 2 degree of freedom universial joing without fighting like the overconstrained 1 degree of freedom stock couple with round bushings.
another factor is shift coupler adjustment, and i seem to get better at it every time. So some of the improvement could be from that too.
Answers to some questions:
the aluminum I used was 6061-T6, aka "aircraft grade" in advertizements. It is basically standard issue aluminum.
I didn't spline it since aluminum on steel is pretty sticky. I did use a rounded cutter on the lathe on my last pass to add a sort of spiral raised surface. only about .005 high. oh, and the engineer shop at work doesn't have a knurling jib had something to do with the decision too.
the pins are 5mm dia hardened steel dowel pins. they are pressed into the aluminum and run thru 5mm+.001" reamed holes in a brass cube. they rotate against the brass. No releative motion against the aluminum. the aluminum arms are .22" thick on each side (.44" total bearing length), and the brass cube is .75" on each side (.75" bearing length).
If it fails on me, i put the OEM version in my repair kit, so that pretty much ensures it won't fail.
All in all, i'm happy. If i had thought about the design first, i would have made it a little different. mostly from a machining secquence point of view. A couple times i had to really think about how i could clamp the parts in the mill. I nearly machined myself into a corner. While the first took 5 hours, to do it again would be more like 2.5 hours.
I have a feeling i might try making a simplified version in the future. I got seat brackets, a telescope mount, and a kayak rack for my girlfriend's mini's factory roof rack to make first.
jason
Paddles: Dagger Ego
Old 10-19-2004, 09:20 PM
hope you got enough of all of us!!!!
Old 10-19-2004, 09:29 PM
