I'm not sure what's correct, but if your trying to get rusted or rounded off bolts/nuts off, buy the Sears "Bolt out" sockets as advertised by Bob Veila on TV, they are sockets with internal biting teeth and they really work well to take off round nuts and bolts. Any Sears carries them
Does this look bad???
I getting ready to replace the aging exhaust system on my '77 911. So I crawl under there today to take some measurements in order to buy the SSIs (thin or thick), gaskets, spray PB on the rusted bolts, etc. I then discovered that not one but two of the exhaust bolts are...bolts going into flange. What do I need to prepare myself for when removing these bolts and shouldn't there be studs with nuts like the others?
Thanks, Dean http://forums.pelicanparts.com/uploa...1098059947.jpg |
yes, Hugh is THAT good. :)
How did Hugh's reply end up the first post in this thread ???
Or is it just me? |
Also Sears has a coupon out right now for $10 off any tool purschase over $20. Coupon: http://f.chtah.com/i/27/217789800/coupon.pdf |
Hey Hugh, can you do that with lotto numbers ?
Hugh is Pyschic, his reply arrived one minute before the post!!!!!!
| All times are GMT -8. The time now is 06:00 PM. |
