oil leaking from air filter housing?
Hello, I have massive amounts of oil coming from a spigot on the bottom of the air filter housing. Can anybody explain this? Is there a small hose that I'm missing or what?
Thanks, Joe
Old 10-17-2004, 12:01 PM
model/year
I forgot the car is a 73T 2.4 MFI
Joe
Old 10-17-2004, 12:03 PM
You have two problems (at least that are apparent from this post!). The first is that you have oil going into your air filter housing through the oil tank breather. This is usually caused by having too much oil in the system. You can do a search about oil level checking so I'm not going to go into that here. The second problem is that you are missing the tube that goes on the bottom of the air filter housing and drains the oil onto the ground where it belongs.
-Andy
Old 10-17-2004, 03:18 PM
Registered abUser
TerryH's Avatar
Car must be running/level/hot to check oil properly.
'81 911SC Coupe SOLD
Old 10-17-2004, 03:39 PM
[i] onto the ground where it belongs.
-Andy [/B]
i like that.
206 637 4071
Old 10-17-2004, 06:29 PM
Designer King
Paulporsche's Avatar
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-17-2004, 08:59 PM
