-   -   Loud, no, LOUD screeching sound from I think the CD box (http://forums.pelicanparts.com/porsche-911-technical-forum/187781-loud-no-loud-screeching-sound-i-think-cd-box.html)
Starless 10-18-2004 11:31 AM
I went to start the car, and the usual high pitch sound from the CD box was a banshee yell. Car started and ran ok but what on earth is that sound? It stopped after about 3 min. It started before I started the engine. Just one click of the key. Is there something other than the cd box I should be looking at. And should i just replace it or is there something else that i can do.
Thanks.
geof33 10-18-2004 12:04 PM
Did you have the heater on or any of the fans???
Starless 10-18-2004 01:17 PM
Geof, you know, right after I read my own post I went out to give it another listen. This time no noise. But I did hear the heater fan blowing. And I thought maybe it's the fan. It did sound like bearings that need some lube. The heater was on. Is the blower motor lubable. Is lubable even a word? I do believe that is the problem.
Craig 930 RS 10-18-2004 01:28 PM
Prob the crappy heater motor - went through 3 of those on the SC in 5 years.....sam sound 1st 2 times, then on the 3rd it just seized.
geof33 10-18-2004 01:38 PM
If you are sure it was in the back, it's the heater blower. If it's in the front, it's the fresh air blower... (very common) Mine does it for a second when it's really cold, then it's fine... Definately one of your blowers though...
