911 electrical consumption
I disconnected everything I could think of in my '86 911; alarm, stereo, clock, and there is still a small drain out the neg. of the battery. Is this the way it should be?
Senior Member
Keep the meter connected and start pulling fuses. When the draw stops check to see which system it is and investigate.
While you are in there clean off the connections of the fuse block. They tend to get corroded over time. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
What year and model car is it?
Some radios and alarm systems have static drains, but it should never exceed 100 mA ... 0.100 Amp!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Designer King
Try the trunk interior light.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Spec stand-by draw for your car is about 16-18 mA....pretty low.
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
