-   -   bulb replacment (http://forums.pelicanparts.com/porsche-911-technical-forum/187936-bulb-replacment.html)
bkrygier 10-19-2004 02:31 AM
bulb replacment
I have a couple of burned out bulbs behind my heating and air control levers on the dash. Is there a simple way of getting at these bulbs?
bk
3.2 CAB 10-19-2004 04:58 AM
What are they on?
bkrygier 10-19-2004 01:28 PM
1983 911 CAB
450knotOffice 10-19-2004 01:53 PM
Is there lighting behind the heating and air control levers? I've had my car for a month and there is no backlighting behind my panel. I just assumed that it wasn't installed - you know, old dashboard style and all. Hmmm. :confused:
84CAB 10-19-2004 02:59 PM
Yes there are bulbs behind there... they are hard to reach but if you lay in the floorboard and shine a flashlight you should be able to see them...helps if you are small and flexable!!
3.2 CAB 10-20-2004 01:03 AM
You should be able to just reach under and pull them out, if I remember right these are all 2 pole plastic lamp sockets. I think it should have one in each upper corner of the switch plate.
bkrygier 10-20-2004 02:05 AM
I had to pull the radio out and then after some bloody knuckles I got them
bk
bigchillcar 06-17-2005 10:54 AM
i'd rather be able to replace by this method as well, but can you access the bulbs with the old factory air ducting in the way? anyone know where to find the correct bulbs?
ryan
Mysterytrain 06-17-2005 11:01 AM
lol, pulling out the bulb holders is the easy part. Get the little f**kers back in requires Zen like skills, flexible fingers and the patience of a saint. A great place for the super white LED's -stick em in and never have to go back again.
bigchillcar 06-17-2005 11:05 AM
ron, did your car have the a/c ducting in place to have to work around? i'm dreading trying to get my 6'2", 220 frame back in that upside down, nearly kill my nearly 40 year old back position. where's a flexible zen master when you need one?? :(
ryan
